I would like to show you my method of making cheap water bases.
While browsing this forum, I observed the walls. They somehow looked like water so I asked my dad. he said that there is a powder used to fill cracks and has the consistency of very thick paint. The braned is named "Calciumine" (?). I decided to give this material a try.
I first made the base with the help of an adult (since I'm still 12) using plywood and 1/2x1/2 wood frame. Then I prepared the "Calciumine" by mixing it with enamel paint. The powder doesn't work with water. The "Calciumine" dries in 10 mins. when using enamels and will stick to the base while it dries in 2 or more hrs. when using latex but it will not stick to the base. I don't know if it works using acrylics. The mixture was then mixed thouroughly and was spreaded all over the base and scraped. The scraping will cause the "calciumine" to form a "wave like" texture.
When it was dry I painted the base with Phthalo Blue in 2 coats. When it was still wet I painted different shades to give the effect of bubbles caused by the movement of ships. I did not paint the white because I am still going to make the waves
When the paint was dry, I then added the waves using modeling clay for about 50 cents or less. The clay should be colored white because they are waves. I added the bow wave, the wake and more waves. The clay give me lots of time to detail the waves.
Then it was time to shine the water because it can't be water if it's not shiny and what i used is my trusted, non-toxic and cheap white glue. it was mixed with a little bit of water and spreaded all over including the ships waves to make the clay a little hard, wait for it to dry and you have a nice water effect
All the materials (except the wood) I used were cheap. I bought them for about $4 or so.
Hope this works!
I will miss you Werner. Fair winds and following seas.
