Need to match spray can color to bottle color-
Gerarddm
Post by Gerarddm »
Found a pefect Model Master enamel, FS30117 Military Brown, to do the wood deck on my 1/700 Yamato. Problem is, hand painting made it look too splotchy. I can't seem to find a spray can color to match, any suggestions? The primer is light gray enamel.
BTW, would hitting the deck with some dullcoat clear even out the splotchiness ( is that a word)?
Or any suggestions for re-stripping, and a different hand-painting technique for an even finish?
Thanks-
Gerard>
Snohomish, WA USA
If you don't know the definition of erudite, you're not.
scratchshipnut
Post by scratchshipnut »
Try it on scrap, but the modelmaster afrika brown spray might satisfy you. I think its normal stock at hobby snobby so anyone should have it
