Sumner/Gearing class DD Ms31/32 Design 16D
David Sandifer
Unlike all other camouflage design sheets I've seen, the design 16 DD Sumner/Gearing sheet doesn't have the 3 patterns from bow looking aft and the 3 patterns from aft looking forward. Aside from looking at individual photos of the 14 DDs wearing Ms 31/32 Design 16D, is there another source that DOES show these 6 views? TIA
RichardAigner
raggs
David Sandifer
Re: Sumner/Gearing class DD Ms31/32 Design 16D
Thank you, Richard and raggs, for your replies.
However, my problem still remains. Dazzle only shows p/s profiles. NHHC shows deck, p/s profiles, bow-to-aft and stern-to-forward views. but only for the other seven Sumner designs. 16D bow-to aft and stern-to-forward views are blank on the camouflage design sheet.
I looked at NHHC 16D for comparable Fletcher and Benson/Gleaves classes, but those are a big leap to Sumner class application. No luck from Friedman's U.S. Destroyers, Sumrall's Sumner-Gearing-Class Destroyers, Adcock's two Squadron/Signal publications, nor Floating Drydock.
It's becoming apparent that the only solution is to comb NavSource photos of the fourteen Sumner class DDs that wore 16D and then to generalize bow-to-aft and stern-to-forward patterns.
By the way, my aim is to capture Allen M. Sumner DD-692 at the Battle of Ormoc Bay 06JAN1945.
