Hello,
what is your method for bending or deforming the plastic parts? I need to simulate the battle damage, so it is necessary to bend a few parts.
Would you do it over a candle? In hot water? Over a soldering iron?
Bending the plastic parts
- PetrOs
- PetrOs Modellbau
Further kits in preparation.
- Sean Hert
- Rob
- PetrOs
- PetrOs Modellbau
Okay, sounds good
How hot should it be?
- Rob
Boil the water. I tend to tape the part to a curved piece of steel (such as a X-acto handle)or wood, plunge it in boiling water then run under a cold tap. To state the obvious, be careful about scalding yourself. I tend to drop the plastic in the water then fish it out with a pair of kitchen tongs.
Works rather nicely.
Rob
Rob
