Calling all Swedish HMS Göta Lejon & HMS Tre Kroner (1947 fans
- JH
Hi All,
I would think it would be an interesting discussion about these fine ships of the Swedish Navy.
Actually is anyone currently thinking, that it's sad that there are no produced models of this navy.
As I 'm about to scratchbuild the whole navy in the period 1940,
( A lengthy process)
so any suggestions to start me off!
Jens
Jens
Be not simply good, be good for something
Henry David Thoreau
Henry David Thoreau
mike mccabe
- Starling Models
- masch3
Wow!
What scale will you build?
And what ship is going to be the first?
Manligheten?
Where do you find plans? I am passing by Gothenburg in August and thought of passing by Sj�historiska museet to see if I can find some plans.
/Magnus
Manligheten?
/Magnus
** lurking after abandoning all projects **
- JH
Hi Mike
It means "Queen" and Gota Lejon would be an interesting build due to the fact she was the pride of the Swedish navy, for nearly 2 decades as being the largest ever built Swedish Ship.
also where can these card models be found?
Magnus I will be building in 1/700 and HMS Manligheten would be a good start and if you could be able to find some plans that would be great or I will
Look at the Krigs- Arkivet
Also one final note, I'll try to keep you posted with pictures of my builds as they take shape.
Jens
Jens
Henry David Thoreau
Henry David Thoreau
mike mccabe
- Starling Models
Jens
http://jsc.pl/store/?d=produkt&id=80
For Gota Lejon, it is a 1:400 card model so you would need to scale it down if you want 1:700 but it can be done through a scanner and photoshop or similar. I thought Drottnig probably meant Queen or something similar.
Mike
Mike
- masch3
Krigsarkivet might not be a bad idea. I'll keep you posted if I can find something in Gothenburg.
There is also something called Marinlitteraturf�reningen, they seem to have some books on the Swedish navy that might (or might not) be of interest: http://www.mlf.org
/Magnus
/Magnus
- urtch
Sorry, that last post was me. This site sells the JSC models mentioned above: http://www.papermodelstore.com/index.php
This is Paper Shipwright's website: http://www.papershipwright.co.uk/index.shtml
I can't speak to JSC's quality, but I've built PS's SMS Rhein and ACW Mortar Barge, and they're really nice kits.
- Edward Pinniger
I'm looking for any information on the Danish coast defence ships Peder Skram, Herluf Trolle and Olfert Fischer, built in the early 1900s. Photographs and reference material for these ships appears to be very scarce, searching the web has turned up a few low-res photos but not much else.
I've heard that there is a builder's model of Peder Skram in the Copenhagen National Maritime Museum, but have not managed to find any more information about this. Does anyone know more?
(Hope this isn't hijacking the thread too much - they're not Swedish ships, but are at least Scandinavian (and the Swedish navy had very similar coast defence ships)
- masch3
Swedish neutrality markings
Swedish ships were carrying neutrality markings (blue and yellow); they looked different between the different ships.
- finnfan
Peder Skram and Swedish warships
Paper Shipwright (papershipwright.co.uk) have just released a model of Peder Skram. They also do models of the Swedish coastal monitors Fenris (1871), Folke (1875) and Solve (1875). I have made their models of the Rendell gunboats, and was very impressed with the quality.
Hope this helps
Hope this helps
- Edward Pinniger
Re: Peder Skram and Swedish warships
finnfan wrote:Paper Shipwright (papershipwright.co.uk) have just released a model of Peder Skram. They also do models of the Swedish coastal monitors Fenris (1871), Folke (1875) and Solve (1875). I have made their models of the Rendell gunboats, and was very impressed with the quality.
Hope this helps
I know, I bought their kit as soon as it was released
(The availability of the Paper Shipwrights kit is the reason I decided to build this particular ship)
The problem is that as I will be building the ship in 1/96 scale, and their kit is 1/250, I really need some more reference for the fine detail of the ship. It's also useful to see pictures of the real ship (or a builder's model) to get an idea of how everything goes together, there are some areas (notably the forecastle) which are quite complex shapes.
Thanks anyway!
sandy
Re: Calling all Swedish Navy fans!
If anyone knows how to get Swedish plans, I would love to hear from you.
All the best
Sandy
All the best
Sandy
- Maarten Sch�nfeld
Some designs of the Dutch navy of the fifties had much in common with the Swedish: Bofors armament and turrets, and Hollandse Signaal radar equipment.
There is a kit of the Dutch destroyer Friesland in 1:350 (Naval Models), components of this kit could be used for a Halland class destroyer of the Swedish navy.
Roger Whittaker +9/13/2023
gnorfen
Sandy:
I suppose you already know about different articles about Swedish warships in the Warship yearly issues. But I suppose you mean more elaborate plans, try with Sj�fartsmuseet in Gothenburg (G�teborg)
http://goteborg.se/wps/portal/sjofartsm/english
or Marinmuseum Karlskrona
http://www.marinmuseum.se/
Best regards
Anders
Best regards
Anders
Amphion
- Amphion
The HMS Sp�r� is a minesweeper of the Ark�-class from the late 50's, early 60's.
Ships of this class saw service into the 80's, some as late as the early 90's.
