Calling all Bayern-class (Kaiserliche Marine) fans
ingura
Post by ingura »
SMS BAYERN in harbour
SMS HELGOLAND during speed trials
Post by Dave Wooley »
Hi Peter super shots and they look so realistic.
ingura
Post by ingura »
Hi Dave,
yes - I love photoshop. But what would it look like without the harbor in the background?
We met 2006 in Dortmund - loved your article about the harbor. At the moment we're trying desperately to get invited with the harbor diorama to the railrod exihibiton in Chatham 2008. This would be great - a model slipway on a slipway... :jump_1:
Hope we meet again some day Dave!
Sincerly
Vlad
Post by Vlad »
OK i actually thought the second one was an RC model. they look very good indeed. :thumbs_up_1:
Vlad
Jefgte
Post by Jefgte »
Nice "fotos "
I like particulary Bayern in the harbour.
Jef :wave_1:
Current 1/700 WL
HMS Repulse
ingura
Post by ingura »
Most interesting is the comparision between SMS BAYERN (WW 1) and BISMARCK (WW 2). Remember - same scale...
moritzk
Calling all SMS Bayern/Baden class fans
Post by moritzk »
Hello,
I want to open a thread for the fans of the german WW1 battleship class SMS Bayern/Baden.
I hope I am not allone!!!:)
Here are some informativ links:
http://www.maritimequest.com/warship_di ... bayern.htm
http://www.maritimequest.com/warship_di ... n_data.htm
http://www.navweaps.com/Weapons/WNGER_15-45_skc13.htm
model:
http://www.mz-modellbau.net/core/bausaetze/baden.html
Some information will fellow!
Myself is going to start the SMS Baden as a 1/350 waterline Model.
About detail etc. I will inform you!!!
I would be happy If some of you would be interested in this thread!
best regards!
Grossadmiral
Post by Grossadmiral »
You're not alone ! I'm also a big fan of those fabulous ships - that's why I've built them all in 1/700 (incl. Sachsen and Wurttemberg). Staying tuned for more.
Dariusz Mazurowski
Dariusz Mazurowski
moritzk
Post by moritzk »
Ohhh yea!!!
Not alone!:)
I saw ur ships at the gallary and on modellversium.de!!!
Fantastic work!
This shipclass is the reason, why I start my first complete scratch-construction!
Currently, I work on the first ribs!
Hope, I can upload some pictures soon!
Calling all SMS Ostfriesland (Helgoland-class) fans
Post by ModelMonkey »
Be sure to have a look at Bernd Villhauer's SMS Ostfriesland
maartenship
Converting 1:350 ICM K�nig into Bayern/Baden
Post by maartenship »
Hey there,
two weeks ago I stumbled across an extensive set of drawings of Bayern/Baden, being directed there by 'the Dreadnought Project' - see for yourself under their post for SMS Bayern/Baden.
Looking closer they revealed a lot of detail, and after working out that these ships had a fixed frame spacing of 1200 mm, nothing stopped me from enlarging these plans to an exact 1:350 scale (my favourite for warship model). It soon started to dawn on me that in fact the hull was nothing more than a slightly up-scaled K�nig type battleship! Length needed 13.3 mm and width only 1.5 mm.
Well, and as creating a hull is the major challenge when converting (or scratchbuilding) a ship model, I quickly saw the opportunity and off I went! Even before I had the kit available I already had turned my attention to another hurdle: I built a 38 cm main turret from scratch, and a friend of mine already promised me to cast four of these from resin. From the same source drawings of the turret were available.
In the meantime I have already cut up the hull, inserted a 13.5 mm plug from plasticard, split the hull at the keel and added a 1.5 mm shim there. Next made a new main deck from 1 mm plasticardlayered a sheet finely grooved Evergreen nr. 2020 on top of it to simulate the planking. So in fact the big hurdle has been taken within an hour: when you know what to do it's really quite simple!
Currently I'm working on the final details of the turret: the bolts (rivets if you will) on top, shown on a very good photograph of Baden on the same website as above.
Of course I know there is still a long way to go: the battery deck has to be built up next, very similar to the K�nig's but totally different in planform. Then the next boat deck layer and the superstructures: I believe these will have to be made largely from scratch, although many detail parts from the K�nig like guns, searchlights and boats might be used.
Well, I'll keep you posted about my progress and I hope I can make some pictures soon to show what she looks like!
Regards, Maarten
USS California BB44
Re: Calling all SMS Bayern/Baden class fans
Post by USS California BB44 »
Awesome model. At first glance, I thought those photos were of the real ship!
Current Builds:
1-350 DKM Z-39
1-350 USS Philippine Sea
Maarten Sch�nfeld
Re: 1:350 Bayern/Baden converted out of K�nig kit
Post by Maarten Sch�nfeld »
Hi there,
As promised, some pictures from my progressing 1:350 Baden.
The ICM K�nig hull was stretched by 13.5 mm at its widest point, and in the keel a 1.5 mm insert was added to get the required beam. Also, the docking keels were added and the shape of the bow was corrected: from the keel to the stem there is a distinct 'kink' at frame 134, which is totaly missing in the kit.
A new deck was added, laid with Evergreen 2020 v-grooved plate. The deck over the casemates was made as per drawing, and the K�nig casemates were juggled as to make the best fit of them, needing several modifications and one completely built from scratch. Also the shelter deck was made.
I also made a 38cm turret plus guns from scratch, and had a friend of mine casting four copies from resin. Well, now on to building the superstructures, I already made the funnels from Evergreen tubing, and modified the K�nigs conning tower into the shape for the Baden.
Well, that's for now, once the superstructures are there I'll show you more.
Maarten
Roger Whittaker +9/13/2023
Maarten Sch�nfeld
Happy New Year to you all, with much pleasure in modelling!
I thought it was time for a little progress update on my 1:350 SMS Baden built. Painting and detailing has started in earnest.
Regards, Maarten
JIM BAUMANN
Post by JIM BAUMANN »
pretty cool and innovative modelmaking! :thumbs_up_1:
JIM B :wave_1:
Maarten Sch�nfeld
Thanks for the comment, Jim!
The Baden has already progressed much further, I should upload some pictures of the built, before it is all done...
By the way: along the same line I'm considering also the conversion of the K�nig into the Friedrich der Gro�e, a Kaiser class. In fact this will be even much easier, as the hull needs to be shortened instead of lenghtened, the K�nigs turrets can be used with small mods, and the superstructure is much simpler than that of the Baden.
Happy modelling!
Maarten
Atma
Post by Atma »
Anyone has any experience/comments for the WSW 1/700 Bayern and Baden battleships ?
Thanks in advance.
JIM BAUMANN
I built mine in 1997.... pre internet ( easier research!!) and pre custom -made PE
its a good starting point- though I guess probably now superseded by the Combrig quality of kits...
encs a couple of though-the -glass case snapshots....
JIM B
Atma
Post by Atma »
I always had WSW's resin offerings high, I shall invest then :)
Maarten Sch�nfeld
Hi,
At 1:700 scale our fellow Dariusz Mazurowski has made great effort to build all four ships of the Bayern class, in varying settings. Check out:
