To camber or not to camber
- simon b
I will shortly start work on a 1/96 RN Type 42 destroyer. The question is whether i depict the deck camber or not. I assume this will make things a little harder (This will be my first semi kit) and the ship will be built for display rather than R/C
- migoat
Re: To camber or not to camber
That is your decision. I don't think it necessarily will make it harder, just different. Look at your subject, is the camber noticable? Do you want it to be an exact scale replica, or are you satisfied making that compromise? Try making a mock up section of part of the deck, one that is flat and one with the camber, what looks better to you?simon b wrote:I will shortly start work on a 1/96 RN Type 42 destroyer. The question is whether i depict the deck camber or not. I assume this will make things a little harder (This will be my first semi kit) and the ship will be built for display rather than R/C
If you where making an R/C model, the camber would also serve a practical purpose. So that leads to the most important question. Why not an R/C model?
No matter what you decide, make sure you post pictures of your project!
Craig
- Laurent
Hi Simon ,
at that scale , if there was camber on the real ship , you have to represent it , it is one of the most important feature on a model ...
look how camber good looks :
it is not difficult at all , just try it ...
Regards ,
Laurent
Regards ,
Laurent
Just call me the "Cereals Box Killer" , I guess
- Model Monkey
Interestingly, the real USS Constitution's spar deck was originally built with camber but at some point in her history that deck was replaced by one without camber. The ship will soon be undergoing another restoration to achieve more of her War of 1812 appearance and the camber will be restored. The restoration is scheduled to be complete in 2009.
- Jose Chaica
