Question on using polyester resin to build hull
toiletfreak
Post by toiletfreak »
Hello, I have made a balsa scratchbuilt hull. Would like to ask if I can use polyester resin as a covering for the whole hull and as a gap filler in place of silkspan? Thanks!
Laurent
Post by Laurent »
Hi Toiletfreak ( ? )
you'd better use a mono-component polyurethane resin , which is easier to use on wood , as there is no mixing to do , just pour the needed quantity in a can and apply with a brush ...
balsa has the property to soak a lot of resin , apply that PU resin as long as the wood "drinks"
your hull will become strong as steel , no fibreglassing needed at all ...
Regards ,
Laurent
spikesliew
Post by spikesliew »
See that you've taken the plunge, dude?! Keep us posted on ur progress! :thumbs_up_1:
Liew
