1/700 helicopter windows painting
J Cheng
Post by J Cheng »
Hi, all:
I have been painting the 1/700 helicopter windows, but I still have trouble stabilizing my hand when I do so. Any suggestions?
Also, what is the best way to make the window frames as detailed as possible for the 1/700 helicopters? Any suggestions?
Thanks....
Carrier Battle Groups, Yeah!!!
Vlad
Post by Vlad »
I use a very thin tipped permanent marker, does the job very well :D
Vlad
You know them Sharpie things you get at Staples? Yeah, those ones with the non-felt tip called Ultra Fine Point. Bad thing is, the tip is not sharp, but rather a circle with the diameter of perhaps two/thirds of an mm, so you have to be careful around the corners...
J Cheng
Post by J Cheng »
Hey, Guys:
Thank you so much for the tips....I'll go and find the pen.... :D
