Home made decals
finnfan
Home made decals
Post by finnfan »
I have had mixed results with home made decals made with inkjet decal paper. The main problem is sealing the image once printed. I have sprayed Microsol decal solution on to seal but still had some bleeding of colours. I have also sprayed with acrylic varnish which works slightly better but results in a rather thick decal. Both methods have resulted in decals which bleed when soaking off the backing paper, even with very short soaking times.
Now I am thinking about alternatives. The subjects I am interested in are usually fairly esoteric, so having a commercially printed set is not economically viable as hardly anyone else is likely to buy the surplus sets. Is there anyone in the UK who will do �one-off� printing?
The latest idea is to buy a colour laser printer (as Alps printers are now out of production), but as it is an expensive option, I would like to know if anyone else has gone down this route and what success they have had.
Any other thoughts on the matter would be most welcome.
les
Post by les »
I've made decals with an inkjet printer with good results. I used the decal paper made by Bare Metal Foil. Then I took the printed decal and covered it with the Microscale Liquid Decal Film out of the bottle with a paint brush. Load the brush up and let the solution flow as much as possible. Don't brush much or you'll smear the decal. It helps to make a couple of sets in case you screw one up. Let it dry completely. Overnight is best and you shouldn't have a problem.
