Paint matches for JMSDF colors
fred_sirois
Post by fred_sirois »
I don't know how popular this thread will be, but if someone can answer my question, it would be appreciated.
What are the accepted colors for vertical and horizontal surfaces on JMSDF destroyers? I'm thinking that they are pretty close to USN modern colors, but not exactly.
Fred Sirois
Tace et Exemplar Aedifica
blandcorporation
Re: Calling all JMSDF destroyer fans!
Post by blandcorporation »
I know that the WEM matches for the JMSDF colors have been discontinued, but the best matches for me have been:
Horizantal: a noticeable shade darker than US Haze Gray. I used Polly Scale Dark Gull Gray.
Vertical: I have been on a JMSDF ship before, and normal vertical surfaces were not much darker then the horizantal one. I ended up using Polly Scale British Ocean Gray.
Helo deck: Gunship Gray.
D-Boy
Post by D-Boy »
This thread also of interest: viewtopic.php?f=69&t=46108
The initial post:
I would like to know what the cross over color for JMSDF ships are in the following brands: Tamiya, WEM, and Model Master/Testors
One suggestion I was given was White Ensign models color M14, with JMSDF Deck Grey being M15. FS35237 Medium Gray. Does this sound right and what would a good cross over to the other brands would you recommend?
edit post.
I have settled on Tamiya XF-20 and XF-54 for the JMSDF DD123 build. The reason why is based on the color chart I found at
http://www.canit.se/~griffon/diverse/mo ... colref.txt
Here is a number of colors and cross over numbers.
I'm posting it here to help anyone who may have the same problem I did in trying to cross match colors that may no longer be avalible or may not be in production.
Here is a short list from the web site.
Fedral Standard numbers matched to Gunze Sanyo, Humbrol, Tamiya, Xtracolor, Polly S
FS.36081 Gunship Dk. Gray: X:X129 P:500014 GS:H301 Hu:32 T:XF-63?
FS.36118 Gunship Lt. Gray X:X130 T:XF-24 P:500822 GS:H305 Hu:125 T/MM:1723
FS.36152 Blue-grey Hu:HN 2
FS.36165 RLM 02 T:XF-22
FS.36173 Dark Grey Hu:156 GS:H82 T:XF-53 P:PCA823
FS.16176 Dk grey F-15 X:X157
FS.36231 Dk Gull Grey T:XF-54 P:PCA824 Hu:140 GS:H57 X:X131 T/MM:1740
FS.36251 Medium grey X:X132
FS.16270 Neutral grey X:X133 T:XF-53
FS.36270 RAF OceanGray Hu:USN2 GS:H306 Hu:126 T:XF-20
FS.36307 Grey X:X134 Hu:141 Light Sea Grey GS:H324
FS.36314 Flint grey X:X143 T:XF-25
FS.36320 Dark compass grey X:X135 P:PCA837 GS:H307 Hu:128 T/MM:1741
FS.36329 Light sea grey T:XF-66
FS.36373 Hu:87 Steel grey? T:XF-25?
FS.36375 Light compass grey X:X136 Hu:127 GS:H308 P:500836 T/MM:1728
FS.36400 Light Stone Hu:121+Hu:90
FS.36424 Medium grey T:XF-20
FS.16440 Lt Gull Gray Hu:183 GS:H51? X:X137 (MiG-29) T/MM:1729
FS.36440 Hu:129 GS:H325/H315 P:PCA825 T/MM:1730 T:XF-20
FS.36463 Hu:146?
FS.16473 ADC Grey X:X138 Light Aircraft Gray Hu:146 GS:H61 T:XF-66?
FS.36473 Hu:64 Light grey? P:PCA806? T:XF-12?/XF-19 T/MM:1731
FS.16492 Light grey X:X147
Reason: Fixed link :) Copying and pasting a shortened link form another forum post doesn't work because it'll copy the shortened url instead of the actual url :)
My appreciation for ships of the JMSDF has been growing slowly, but steadily. I don't have a definite answer to the question of color, though I do have several guides at home that I will look at.
I did look at the paint call outs for PitRoad and Tamiya: PitRoad indicates two different modern greys and has formulated paints accordingly. The callout from the Tamiya Ohsumi kit indicates Haze Grey as the main grey. Their match is TS-32.
Toshifumi Kimoto has long been a pre-eminent modeler of the IJN in 1/700. He has branched into the modern JMSDF as well and has several excellent builds in his galleries, along with build logs. See: http://homepage2.nifty.com/vanguard/
Model Graphix just published a volume dedicated to the JMSDF and Toshi-san built all of the models depicted in it. I have it & highly recommend it to fans of the JMSDF. Here's one link: http://www.hlj.com/product/MDG23054
D-Boy
Post by D-Boy »
Dan K wrote:My appreciation for ships of the JMSDF has been growing slowly, but steadily. I don't have a definite answer to the question of color, though I do have several guides at home that I will look at.
Thanks, Dan K! Been tempted by that volume at HLJ and appreciate the quick endorsement. And intriguing to know that Kimoto-san has branched into JMSDF.
According to the Model Art IJN Paint Camoflage Guide translation, modern paint technology allowed greater standardization of paint for the postwar JMSDF and in 1957, a std. grey matching Munsell color #5 for ship's hull was specified, as was a dark grey for ship's deck matching Munsell #4.
I do intend to write Toshifumi Kimoto for information.
modeltaskforce
Post by modeltaskforce »
I understand WEM has stopped making the paint for JMSDF ships. What does everyone else use for the hull, decks etc :thumbs_up_1:
D-Boy
Post by D-Boy »
modeltaskforce wrote:I understand WEM has stopped making the paint for JMSDF ships. What does everyone else use for the hull, decks etc :thumbs_up_1:
See this discussion: viewtopic.php?f=69&t=46108
