Danish navy received two new frigates
maxim
Post by maxim »
The Danish navy received two new frigates:
Absalon (F341) and Esbern Snare (F342)
They were re-classified from "fleksible st�tteskibe" (flexible support ships) to frigates, much more fitting to their characteristics. Accordingly, the hull number changes from L16 to F 341/L17 to F342. I.e. not new ships, but newly classified ships ;)
The main task of the two ships will be from now on anti-submarine warfare. For their MH-60R Seahawk helicopters, ASW equipment is already on order. I do not know, if they will also get a towed array sonar (there is space available).
Source:
https://www.dr.dk/nyheder/politik/med-m ... erligt-ord
Re: Danish navy received two new frigates
They will be getting towed-arrays, but those won't be in service until 2026: https://forsvaret.dk/da/nyheder/2020/so ... fregatter/#
maxim
Post by maxim »
Thank you! That article I was searching yesterday, but there was no access to the server of the Danish military. I found only the DR article and the Danish Wikipedia article, which referred to the DR article.
The possibility to add a towed array sonar was mentioned very early on - interesting that they will get them. That means there will be again a ASW capability.
maxim
Post by maxim »
Here something about the towed array - that a tender was launched:
https://www.navalnews.com/naval-news/20 ... -asw-role/
