Bending PE
Bending PE
Post by Guest »
Ok I'm doing well glueing the PE along the sides of the ship but how do you guys go about when attahcing to the bow as I can't make the pe stay as the shape of the bow so do I just glue it down and hold it till it sets or is there a way to bending it.Also sorry for the noobiish question.
ingura
Post by ingura »
Sylvain Auger
Post by Sylvain Auger »
If you are trying to form a roundish section of PE railings then I suggest pre-bending using a wood dowel or anything round to make the bend. Always keep in mind that PE will tend to spring back to it's original form so to acheive a good bend you actually have to bend the shape tighter than you need and once it's springs back a little you get the right fit.
Hope this helps! :wave_1:
Ventis Secundis
Gerarddm
Post by Gerarddm »
As much of a pain and time-consuming as it is, you must always pre-bend PE to the intended curve, and keep dry fitting until it is perfect. THEN glue.
The only exception I can think of are the gentle curves that follow the sheerlines of ships.
Gerard>
Snohomish, WA USA
If you don't know the definition of erudite, you're not.
Post by Guest »
Alright thanks guys your a big help.
