The Drive
This Mini Vertical Launch System Can Give Small Ships And Trucks Huge Firepower
The modular launchers bring the very capable Joint Air-to-Ground Missile, and possibly more, to light vehicles and small patrol ships.
By Joseph Trevithick December 18, 2020
The War Zone
Lockheed Martin has developed a four-round launcher for its new AGM-179A Joint Air-to-Ground Missile, or JAGM, that is designed to be readily installed on warships, including relatively small patrol boats, as well as ground vehicles. This opens up entirely new possibilities for JAGM, which was initially developed primarily as an air-launched anti-tank weapon, in the surface-to-surface role.
The JAGM Quad Launcher (JQL) leverages technology from Lockheed Martin's existing Vertical Launch System (VLS) designs, which include the popular Mk 41 VLS found on numerous warships in the U.S. Navy and other navies around the world. It also uses the same Launcher Electronics Assembly (LEA) from the M299 launcher, a four-rail design for helicopters most commonly associated with the AH-64 Apache. All of this combined with an open-architecture Launcher Management Assembly (LMA) designed to help speed up the integration of updated hardware and software as time goes on to improve the JQL's capabilities and add new functionality.
(...SNIPPED)
