Hi everyone
Because I build models of USS California and West Virginia from polish publisher GPM scale 1:200 I'm looking for drawings for cage/lattice mast.
Best regards
Chris
Cage/lattice masts USS Battleship
Re: Cage/lattice masts USS Battleship
Chris:
Perhaps you would find success with your questions In the "Calling all ship fans" area, a lot of technical and resource discussion occurs over there!
Regards: Tom
Regards: Tom
Pieter
Assuming there is no 3D print availabie in 1/200 I can give you the thread with the 'classic' way of doing cage masts. Photo etch will not work and as you are building in a large scale you should be able to get a nice result with brass rod.
viewtopic.php?f=4&t=21203
It is actually good fun to make one. Much nicer than staring at high polygon .stl files on a computer. This is my own attempt on a build that stalled after doing the cage mast rather than before doing one.
viewtopic.php?f=59&t=160087
j leyland
This is how I did it a long time ago. Hope it is of use. John Leyland
