Calling all US Navy Swift Boat fans
Hajo L.
Post by Hajo L. »
Good day mates!
Usually I build aircraft and helos, but occasionally I do build boats as well. For instance this one:
https://www.modellversium.de/galerie/14 ... enbau.html
(WIP here: http://www.arcforums.com/forums/air/ind ... m-scratch/)
Ok, enough of me, I came here to learn! Since my favorite scale is 1/72 and I usually focus on "modern stuff" (= anything after 1945), the announcement of the 1/72 Swift Boat by Revell was a very pleasant surprise for me!
Now my question: Have all "in country" Swift Boats been dark grey, or were some painted in green as the PBRs?
HAJO
dhenning
Re: US Navy Swift Boat colors
Post by dhenning »
I think that I have seen photos in both grays and greens. Some of the dark gray photos can look almost green. Good question and hope that someone can provide a firm answer (along with recommended paints for the paint schemes). I have the old Monogram 1/48 kit in various stages of construction from years ago that I need to finish.
maccrage
Post by maccrage »
Here's one of each.
Hajo L.
Post by Hajo L. »
Thank you, much appreciated!
But apparently only a few boats were green, so far this is the only picture I know. All others I found were dark grey.
HAJO
William Smallshaw
Post by William Smallshaw »
During operation Market Time Swift boats were engaged in coastal interdiction. These boats were painted overall US Navy modern haze grey. Decks were dark grey non-skid. As the boats shifted to riverine interdiction work they were painted dark green. I have used Marine Corps Green to paint models of these boats. This color appears to be close to contemporary photographs. That said if some one provides a source that specifies the color actually used, I am all ears :-)
Fishermandave
Post by Fishermandave »
Went fishing in Rockport TX a few months ago and there was a swift boat tied up next to us.
My guide said if I let him know next time we can go for a spin in the swift !
Hajo L.
Post by Hajo L. »
I got some other source that is mentioning green...:
Paint Scheme:
Original: haze gray overall - factory applied color
Vietnam : deck gray with varying amounts of black added, white mortar box lid and a large white star, in a blue circle, on the pilot house roof
Riverine: dull green with black camouflage patterns - authorized in May 1970
http://swiftboats.net/extras/boat_specifications.htm
Cool, even a camo-pattern! But I haven�t seen any pictures of that yet.... Even the green ones are very seldom, with the picture above here beeing the only one I know so far.
HAJO
maccrage
Post by maccrage »
Camo. Can't see the pattern though.
maccrage
Post by maccrage »
Hajo L.
Post by Hajo L. »
Awesome! I�d go with a field modification paint job = put black patterns wherever you think it looks good.
HAJO
maccrage
Post by maccrage »
That looks like what they did. And here is a view of the star on the roof, if you use one. Note that the spotlights and such were painted the background color.
Hajo L.
Post by Hajo L. »
Thanks a lot! If you have any more pictures of green Swiftboats...
I�m looking forward for the kit to be released this summer and will put it on my workbench ASAP.
HAJO
maccrage
Post by maccrage »
Hajo L.
Post by Hajo L. »
maccrage wrote:Camo. Can't see the pattern though.
What�s the purpose of the net at the bow?
HAJO
maccrage
Post by maccrage »
I'd assume to get back onboard after getting off on the riverbank.
ETA: you can see the net, and how high the bow is, here.
Hajo L.
Post by Hajo L. »
Picture of a prototype-model can be seen on the homepage of Revell:
Let�s put it friendly: There is much room for improvement by an experienced modeller.
HAJO
Hajo L.
Post by Hajo L. »
Forgot: Decal options will be PCF-9, PCF-65, PCF-103.
HAJO
Post by Guest »
Haze gray and riverine green are valid choices depending on area of operations - coastal or river. Dark gray is a good choice for coastal patrols. Talking with two different PCF vets the dark gray was a home brew so you have a lot of leeway in final tone. The first PCF's I saw at Sa Dec were Haze Gray as I recall.
Hajo L.
Post by Hajo L. »
I have the kit now! If you want pictures of the sprues, just say it...
HAJO
Hajo L.
Post by Hajo L. »
Can somebody shed some light on that equipment that�s right to my Playboy-centerfold?
Because of it�s shape and the position on the kitchen-pantry I�m close to call it a coffee-machine (probably as important than Diesel-engines for the functioning of the boat... ;) ), but the seat right at the position may indicate it�s a radio. Any ideas?
Also, not pictured here, but on the port-side inside the cabin, is that a bunk-section?
HAJO
