Shore Bombardment Effectiveness?
- Sean Hert
Spurred by Werner's 1937 Thread I was wondering what the real effectiveness of shore bombardment was. It seem to have been great for taking out shore batteries and such, but as far as "bouncing the rubble" goes, did it do much more than provide more cover for infantry?
Is there some sort of established BDA information?
Reason: added = to url
Sean Hert
Sean Hert
Rich Mathsen
Re: Shore Bombardment Effectiveness?
It seems as though the effectiveness of shore bombardment was overestimated early on, Tarawa being a good example. The US Navy got better at it with more experience. However, the Japanese learned lessons well, too. Iwo Jima got pounded for quite some time prior to the landings there, but the Japanese were so well dug in that the Marines still took serious casualties.
- Werner
I really think the effectiveness is governed by terrain and to a degree by how well the troops are prepared. The biggest effect is in impact on the morale of the soldiers. Holes in Henderson Field were repaired before lunch and even most of the damaged planes were airworthy within hours or days.
Japanese troops already prepared to die are unlikely to suffer much from a bombardment except for a direct hit.
-- "A Nation at Risk" (1983)
ar
The best area of study would be that of the Normandy campaign.
- Werner
But that's such a huge operation.ar wrote:The best area of study would be that of the Normandy campaign.
- Did the bombardments actually occur at the same place as the landings?
- Did the bombardments have sufficient depth and air spotting to interfere with reinforcements?
- Was the European D-Day bombardment sufficiently long to neutralize shore defenses to the D+1 line?
I'm sure the issue of collateral damage was very much more important in Europe.
- Mark Petersen
At Normandy perhaps the effective shore bombardment was when some the destroyer captains off Omaha practically drove their ships on the beach to engage German strong points and pillboxes on the bluffs. Against troops defending a position in open trenches naval bombardment should be very effective provided it uses proximity fuses to detonate the round at the right height above the ground. Against heavily built defenseive positions ala the type of concrete bunkers that were built as part of the Altlantic Wall then you are left with three options, 1) carpet bomb the area with heavy bombers and hope you get lucky, 2) dive bombers or gunfire. Gunfire and dive bombing can both suffer from the same problem. Ater the first few shells or bombs you then have to deal with spotting the fall of shell or seeing the target to aim the bomb due to all the smoke you or the enemy is making. But in todays world the idea of gun fire support has largely been given over to aircraft flying cover doing close air support. Add in the newer guided munitions the only possible advantage that navl gunfire can have is the ability to be there foe longer periods of time. Even that might pale against a cell of B-ones or BUFFs orbiting overhead with a full load of precision munitions and the troops on the ground trained to employ them.
It's my $.02, not yours. Feel free to spend yours. I won't stop you
ar
You and Werner are a little off point.
The word was "campaign", not JUST the landings.
Bombardment went on for about four or five weeks I believe.
You have to look at the ENTIRE thing.
- Werner
I know I will pull my Morrison's D-Day volume off the shelf before I turn in tonight....
- JWintjes
- Location: turning into a power-hungry Yamato-models-munching monster... buahahahaha...
Shore bombardment is really an interesting topic - right from Caesar onwards.
I must admit, though, that I'm sceptical at the idea of drawing general lessons from any particular operation. As far as my limited understanding goes, the effectiveness of coastal bombardment depends to a great extent on the topography, other natural factor and ultimately on the nature of your targets, ie what you actually haul your ammunition at. Already WW1 experience shows that if you can pinpoint your targets, then it's possible to take them out with great accuracy - if you can see it, you can hit it. Conversely, problems arise when faced eg with mobile artillery.
Generally I'd say that the effectiveness of coastal bombardment depends first and foremost on the intelligence you have of your targets. If you know where to shoot, chances are you get enough suppression on the enemy that it will make things easier for your own troops. If however you are unable to locate the right targets, then even the most sustained bombardment effort is pointless.
Jorit
Jorit
- Werner
Morrison said coconut log shelters under a few feet of crushed coral were nearly impervious to heavy artillery and aircraft bombs,JWintjes wrote:Shore bombardment is really an interesting topic - right from Caesar onwards.
Jorit
ar
Which is why (although not perfect) the Normandy CAMPAIGN is the very best SINGLE area of study for this subjectJWintjes wrote:Shore bombardment is really an interesting topic - right from Caesar onwards.
Jorit
- JWintjes
Jorit
ar
Jorit
- JWintjes
Hm. I'm inclined to disagree as far as operational aspects are concerned, but you probably mean that there's much more data available for Normandy, and that's undisputable of course.
Jorit
Jorit
- Devin
It probably also has something to do with weather conditions: the morning of June 6 saw varying weather over the beaches, the ones with cloud cover did not get as much ordnance on the beaches prior to the landings. The landing infantry at those sites suffered proportionately more casualties than the beaches that had clear weather for pre-landing bombardments.
- chuck
Who can dispute that, if the enemy were defending the coasts of a reasonably large land area and therefore must rely on heavy mobile forces to perform elastic defence in depth followed by powerful mobile counter attack, rather than a fixed dug in defense of the beaches , then the artillery support of a naval forces would be able to exert a dominating influence over the 20 miles or so of combat zone. Pacific islands actually fought over during WWII were small and hardly able to support any serious heavy mobile defense. This is why those who dugs deep into the pacific experience can question the value of naval artillery fire support. But I think that type of amphibious action is probably somewhat unique to the pacific war, and more likely types of decisive amphibious action would be against a large land mass protected by a powerful mobile armored land force.
ar
Like others, you are off point.Devin wrote:It probably also has something to do with weather conditions: the morning of June 6 saw varying weather over the beaches, the ones with cloud cover did not get as much ordnance on the beaches prior to the landings. The landing infantry at those sites suffered proportionately more casualties than the beaches that had clear weather for pre-landing bombardments.
Am NOT talking about the 6th of June but the whole FOUR TO FIVE WEEKS of bombardment!!!!
- Devin
In that case I misunderstood, I thought we were talking mainly of sea based bombardment, which did not occur until immediately prior to the landings (that whole keeping the location secret thing), and admittedly I have no knowledge of fire support after that date.ar wrote:Like others, you are off point.
- JWintjes
ar wrote:Like others, you are off point.Devin wrote:It probably also has something to do with weather conditions: the morning of June 6 saw varying weather over the beaches, the ones with cloud cover did not get as much ordnance on the beaches prior to the landings. The landing infantry at those sites suffered proportionately more casualties than the beaches that had clear weather for pre-landing bombardments.
Yes, but that was fundamentally a three-dimensional affair. So it's not really suitable for observing the effects of naval bombardment alone. Which is why I still think Dardanelles is the better example.
Jorit
- Tim Jacobs
Don't forget the Italian Campaign where the Germans learned the hard way just how well 6 inch cruiser fire could disrupt attacks by armor formations as well as disrupt their staging areas. (can't remember if it was Anzio or Salerno)
On the workbench:
I Love Kit 1/72 OSA-I
Recently completed:
Das Werk 1/16 Panzer III Ausf. J (early)
Trumpeter 1/35 SA-8 Gecko
Trumpeter 1/350 Moskva (Slava-class)
Recently completed:
