Calling all CSS Alabama (1862) & USS Kearsarge (1862) fans
Wood hull, steel hull, powered sail / wood or plastic models.
DanCinSD
Re: Calling all CSS Alabama & USS Kearsarge fans
Post by DanCinSD »
:wave_1: Hi, okay, i've got the revell kit. Is there a review that lists the inacuracies of this kit? Any good plans or drawing to show what needs to be corrected and help in added details??
Steve are you building one of these??
Thank you
Dan
Post by ModelMonkey »
IMHO, Joel Labow's review of both Revell kits on the "other" site is very well researched and helpful :
http://www.steelnavy.com/Alabama&Kearsarge.htm
An excerpt:
"The Revell Kearsarge was truly one of the most carefully researched styrene models of its day and with her quarterdeck and conning platform restored could easily serve as the basis for an extremely accurate model of this famous warship at the end of her career. Unfortunately, the modifications required to backdate her to her 1864 appearance would involve an extensive revision of almost all external hull details above the waterline as well as replacement of many kit-provided small parts...The Revell Alabama, on the other hand, bears only a general resemblance to her prototype since the hull and many of the parts were based on the Kearsarge. The good news however is that the kit has just enjoyed a limited re-release and is readily available, and aside from the concerns noted is a good kit which makes into an attractive model out of the box. A modeler who wanted to build an 1864 Kearsarge in plastic could make a good beginning by using this kit rather than the very hard-to-find Kearsarge as a starting point (and it would be LOTS cheaper!). Ironically, the cutdown bulkhead lines of the Alabama kit make it resemble the lines of the 1864 Kearsarge more closely than the kit which bears the Kearsarge's name."
Seeing a few of these built beautifully right out of the box, I'd like to build one or the other of these kits sometime in the future.
Werner
USS Kearsarge (1864) question
Post by Werner »
Could someone familiar with USS Kearsarge and the battle with CSS Alabama please answer my question in the History section?
Thanks!!
-- "A Nation at Risk" (1983)
johnny canuck
Re: Calling all CSS Alabama (1862) & USS Kearsarge (1862) fans
Post by johnny canuck »
Hello,
I just purchased the book, "CSS Alabama, Anatomy of a Conferate Raider" by Andrew Bowcock. I haven't read it all yet but the book does have deck plans, profiles, and detail drawings of guns, rigging etc. The drawings are not anywhere as numerous as the Conway Anatomy of a Ship series but along with the detail photos of the 2 builders models of the Alabama, provide enough detail that I think one could build a reasonable replica of the ship. The book was about $50USD at Amazon.com including shipping.
James W.
Dry docked:
1/72 HMCS Assiniboine DDE 234-1960
1/72 HMCS Ottawa DDE 229-1960
1/72 HMCS St. Catharines-River Class Frigate-1944
On the slipway:
1/72 HMCS Camrose-Flower Class Corvette-1943
1/72 HMCS Trillium-Flower Class Corvette-1942
captKangaroo
Post by captKangaroo »
Hello,
I am presently building the Revell 1/96 scale model of the CSS Alabama, and have a couple of concerns. This is my first attempt at a sailing ship with thread for rigging; but even at 52 yrs. old, I decided to try, since I built many models in the past. Can anyone who has built this model tell me whether there is plenty of the tan thread, and plenty of the black thread? I've been very careful not to waste any, and though I have only used thread on the 2 larger guns, so far, I am already wondering about whether I should buy more, and where to get it. Also, I'd like to locate a source for a replacement for the spanker gaff (part 160), which is curved (might have to heat and straighten); and a dingy davit (part 84), as one is broken.
There are discrepancies on advised colors for many parts, if you compare box art, box model pictures, and the instructions; so I have done a lot of research, using the internet, the book CSS Alabama - Anatomy of a Confederate Raider, and the book Shark of the Confederacy. Apparently, when the ship first sailed, the masts were "bright", which I found means not painted, but varnished with several coats. Also, the boats were described as black. These details are agreed upon by both of the above books, but who knows...this could have changed over the next two years. If anyone would like further ideas on colors, just ask... I'm painting everything! "Gun Metal" for the guns, "Rubber" for black painted wood, etc. CaptKangaroo
les
Post by les »
If I were to build it the first thing I would throw away would be the rigging thread. Good thread can be found by going to the Model Expo site or checking on some of the other manufacturers like Billings Boats. As for the spanker gaff, you could either make a new one out of Evergreen Plastic or get a tapered one out of wood from one of the sites above. The lifeboat davits should be available through one of the model ship suppliers in metal or you could scratchbuild your own.
I would suggest that you look up the sailing ship sites on the net. Also you might buy a copy of Ships in Scale magazine. It's primarily for wood kit builders and has advertisements for suppliers. You also might go to [url]modelindex.com[/url] . It is a site divided into links to modeling sites, categorized by type (AC, Armor, Ships, etc.) Finally, I would highly recommend Les Wilkin's book on building plastic scale model sailing ships. It has a lot of tips in it. You can probably find a copy on ABE Books website.
Hope this helps.
JWintjes
Post by JWintjes »
As for rigging threwad, I can recommend "CIM-Rope":
http://www.cottage-industry-models.com/Accessories.htm
A tad on the expensive side, admittedly, but it looks next to fantastic.
One minor warning about the kit (which you probably know anyway, as you have the Bowcock book) - it's more a general approximation than a true replica, being essentially a Kearsarge with some modifications. I'd consider scratchbuilding the main guns, as they are so prominent features.
Jorit
johnd13
Scale Decks
Scale Decks
Post by johnd13 »
Time for some long overdue updates on the CSS Alabama...
I've obtained both the Revell 1/96 USS Kearsarge and CSS Alabama kits, and have started to go deep on studies of these two kits. At first glance, the Kearsarge appears to be a fairly accurate representation, but the Alabama has all sorts of problems - particularly with the guns and the sweeps for the pivot guns in particular.
Here's a photo of what I am talking about:
Photo of deck plans and the plastic decks from the Revell 1/96 CSS Alabama (Top) and Revell 1/96 USS Kearsarge (Bottom)
The top deck (molded in off-white) is the Alabama, and the bottom deck (molded in brown) is the Kearsarge. If you compare both decks (with molded-in raised gun sweeps highlighted in black marker) to the deck plan immediately above, you will see that the Kearsarge pretty closely represents the layout of the guns and sweeps. The Alabama kit, a derivative of the Kearsarge, basically just "makes up" what the gun sweeps supposedly looked like, as they are in no way similar to the most accurate deck plans (and plans based on actual research of the wreck located of Cherbourg!)
I've been talking to the folks over at Cottage Industries, who make gun upgrade kits for the Kearsarge and Alabama in resin and cast metal. Check these out!
CSS Alabama Gun Upgrades from Cottage Industries
USS Kearsarge Gun Upgrades from Cottage Industries
You can order them here:
http://cottageindustrymodels.com/?page_id=289
Both kits are in 1/96 scale and contain all the guns you need to properly outfit each ship.
You may note that the CSS Alabama guns are placed on the inaccurate sweeps from the Revell kit. What scaledecks.com plans to do is to introduce a new wood deck to cover up the inaccurate sweeps in the Revell deck, and then cover it with a fully-planked deck (no three piece splice action here!) and then provide a set of sweeps (laser cut, perhaps with some sort of mounting template) to allow you to create all FOUR sweeps - not just for the main pivot guns, but also for the chase guns at the bow and stern as the Alabama had.
You can see how our 1/96 USS Constitution deck turned out in a build log here:
http://cs.finescale.com/fsm/modeling_su ... 55174.aspx
If you have any ideas or suggestions regarding the CSS Alabama (we'll be tackling that ship first) or the USS Kearsarge, please contact me at johnd@scaledecks.com and we'll try to incorporate your ideas into our offering.
Thank you!
-- John D. --
scaledecks.com - Proud Sponsor of the ModelWarships.com community!
maxim
Post by maxim »
I have finished now my 1864 versions of USS Kearsarge and CSS Alabama - both 1/700, scratch built - and I had not thought about to search in CASF sailing ships section for them! Especially Kearsarge was optimised for steaming and a poor sailing ship (at least in 1864, later she was converted to sail better; typical for the US Navy in the Dark Ages of the 1870s).
viewtopic.php?f=59&t=154076&start=40
USS Kearsarge (1/700, scratch)
CSS Alabama (1/700, scratch)
dafi
Post by dafi »
Simply wonderfull!!!
Thanks for build and pictures!
XXXDAn
To Victory and beyond ...
Ronald47
Post by Ronald47 »
Hello guys,
Pushing up the topic; Have aquired the USS Kearsarge from Revell in 1/96 (and payed to much, but who cares :) ). Want to build het in Civil War outfit. I know the Cottage Industries upgrade kit for the guns, but I know that in the Civil War the ship looked different from what the kits looks. That is at the end of her life.
What plans or sources can I use to backdate her to the Civil War?
Thanks ;)
Greetz, Ronald from the Netherlands.
My Blog: http://metusajunction.blogspot.com
My photos: https://www.flickr.com/people/52307730@N06/
maxim
Post by maxim »
Hi,
my model of the Kearsarge shown above is in the 1864 fit. It is based on the articles Reconstructing USS Kearsarge, 1864 by Arthur C. Roberts published in Nautical Research Journal 44(4), 45(1), 45(2) und 45(3) (December 1999 to September 2000). These articles contain most of the necessary drawings. I have not seen the 1/96 kit, but the main problem is the stern. The stern of Kearsarge was rebuilt and the as far as I know the kit shows it after the rebuilt. Kearsarge had a much more pronounced sheer in 1864 compared to later fits.
Lars
Ronald47
Post by Ronald47 »
Oke Lars, thank you very much! Where to get these journals?
maxim
Post by maxim »
It is the Nautical Research Journal (there was a spelling error in my last posting):
http://www.thenrg.org/the-journal.php
Ronald47
Post by Ronald47 »
Thanks Lars, already found them! Think I buy the cd :)
William
Post by William »
Scaledecks recently released a wood deck that corrects many of the deck fittings errors of the Revell kit of the Alabama. It is a good place to start for anyone interested in doing the myriad of necessary alterations to that kit in order to build a semi-decent representation.
Bill Morrison
Nino
Post by Nino »
William wrote:Scaledecks recently released a wood deck that corrects many of the deck fittings errors of the Revell kit of the Alabama. It is a good place to start for anyone interested in doing the myriad of necessary alterations to that kit in order to build a semi-decent representation.
Bill Morrison
Hi Bill,
I had looked into Scaledecks "decks" and was planning on a purchase till I saw the gene1 build over at FSM. When I feel ready, I think I will try his pencil and stain technique first and get a second kit to do corrections along with Scaledecks correct deck later.
In the mean time I am writing to Revell Germany for any info on a planned re-release of the Kearsarge and Alabama. These OEM's miss out on a bunch of sales. All the modelers who want the OOP kit buy a "used" one so when the OEM's finally re-issue it all the major modelers who wanted one, already have one! In my case I would want a second one-for practice!
Any rumors out there on future Revell Ship releases?
Nino
William Morrison
Post by William Morrison »
I have completed all of my work on modifying the Revell kit to closely match the drawings in the Bowcock kit, including using the Scale Decks wood deck and pivot gun rails, surgically altering or scratch building various deck furniture, using the set of guns by Cottage, adding crosstrees to the head, planking over the false windows at the stern, and have cut wedges out of the mounting stubs to the masts to provide an 8 degree rake. I have also opened and relocated gun ports and scuppers to reflect Bowcock. I believe that I will ultimately have a close approximation of this historic ship!
Bill
Killerbeans
Post by Killerbeans »
I have an Alabama in the stash, as well as a book by Summersell, which includes some drawings. Is anyone familiar with the book?
Return to “Sailing Ships”
