Scratchbuilding Barbettes?
Sauragnmon
Post by Sauragnmon »
I'm working on the build of my Japanese Panzerschiffe, the Koya, and I'm having the fun of trying to figure out which means I'm going to build the twin 16" turret barbettes for the mountings. Thus, I'm looking for input - how would you guys go about scratchbuilding a pair of barbettes to fit the mounting for the turrets?
Rob
Re: Scratchbuilding Barbettes?
Post by Rob »
slice up brass tube of the correct diameter and detail the outer face as you see fit,
cheers,
Rob
ingura
Post by ingura »
Sauragnmon
I'm personally working in 1/700, for budget and space concerns. Sorry, I wrote it before bed, so I wasn't quite thinking straight, all the details and such. Brass Tube is an interesting idea, aside from the cutting required to fit it into the existing deck and structure construction, but I'll consider the idea.
Gerarddm
Post by Gerarddm »
When I did my A140A I simply glued thick plastic sheet in several layers to the bottom of a disc that had the proper diameter, then sanded to size. A bit awkward I suppose and fiddly, but worked fine.
Gerard>
Snohomish, WA USA
If you don't know the definition of erudite, you're not.
ingura
Post by ingura »
Karsten
Post by Karsten »
Scroll down to where JB shows how he did it and the finished Barbettes in detail are posted below.
http://www.modelwarships.com/reviews/sh ... ildup.html
Karsten
