Problems cutting Gold Medal Models PE
TheDuneSea
Post by TheDuneSea »
I am sure I am not the only one but the search function did not deliver any answers.
So, I am having serious troubles working with 1/700 GMM photo etch as all the blades (high quality modeling & surgical blades that go through almost everything like a hot knife through butter) I use won�t really cut it from the frame. Either the parts come off severely bent, there is a lot of cleaning necessary or the blade is damaged.
So I thought about getting some super fine scissors. What are your preferred tools when it comes to really sturdy PE parts?
Best regards,
TheDuneSea
Re: Problems cutting Gold Medal Models PE
What blade shape are you using and what surface are you cutting on? I don't have issues (well, not any more issues) cutting with a curved blade on a piece of ceramic tile.
MM2CVS9
Post by MM2CVS9 »
I use just a standard curved Exacto blade. I used to use a ceramic tile for the cutting board, but switched to a piece of 1/2" thick UHMW plastic.
I cut the sprue close to the waste part of the fret, then trim it close with one of two Xuron shears designed for cutting brass or stainless steel PE, # 9180 (Longer), # 440 (shorter). Then, with a swipe or two from a diamond hone (bought at a fishing supply place, used for sharpening fish hooks I think), lightly dress the edge.
Just takes a bit of patience.
EJ
" 1/700Hasegawa 45
" 1/700Dragon 44
" 1/700Trumpeter 43
" 1/540Revell vintage 62
" 1/350Trumpeter 42
Fair Winds and Following Seas
David Griffith
Location: Waiting for HMS Glatton in resin. Not holding my breath!!
Post by David Griffith »
Try using a proper Swann-Morton scalpel blade. They are much more robust than X-Acto, which I have always found to chip and blunt as soon as you look at them. As above, use a curved blade on a ceramic tile or a sheet of glass.
Another idea. Try turning the fret over and cut from the back side. It gives a slight gap under the attachment point when you cut, and that can be easier.
The material that GMM use for their photo-etch is very tough, and I find it harder to work with too.
Regards, David Griffith.
"For scientific leadership, give me Scott. For swift and efficient travel give me Amundsen. But when you are in a hopeless situation, when you are seeing no way out, get down on your knees and pray for Shackleton."
Joseph Dunlap
Post by Joseph Dunlap »
After going through a great many #11 blades and having the tips break, I started using a narrow X-acto chisel blade with most of it ground away until only 1/8 to 3/16 of an inch is left. This allows adaquate pressure to make the cut with no worries of the blade breaking. It also allows for re-sharpening using first 6K and then 12K sanding film
spejic
Post by spejic »
Do not use #11 blades to cut photoetch parts on a hard surface like ceramic tile. The tip can fly into your eye and it really really hurts.
I used a curved blade (I like the #12) and just keep a sharpening stone nearby when I'm doing that kind of cutting.
"Those of you who volunteered to be injected with praying mantis DNA, I've got some good news and some bad news." - Cave Johnson, Portal 2
Ragnar
Post by Ragnar »
One thing I learned when working with super small details is to wear my Optivisors , not only great for magnifying these tiny bits but protects the eyes also!
