diorama
tcg_yavuz
diorama
Post by tcg_yavuz »
how do you make the sea???
johndon
Post by johndon »
Have a look at this site: http://www.naritafamily.com/howto/Misso ... _frame.htm which includes details of how the sea for a diorama was made.
HTH
John
JIM BAUMANN
Post by JIM BAUMANN »
Ahoi!
There are any number of ways of representing the sea-- some people make the sea from wood and carve a pattren into it-nice but tedious!
I have copied and pasted below 2 differing methods from the HOW_TO section off the front page--always worth a look first!
This is a method used by many modellers, consigned to print here by JEFF HERNE.
Below that is my somewat lesss conventional method--this also works....
Good luck
JIM BAUMANN
Water by Jeff Herne:
those of you who build waterline models, realistic water has always been a serious problem. Many modelers use the 'shower door' glass, but I've found the patterns are often not to my personal liking, and the super flat surface of the glass wasn't too realistic.
The old methods of using epoxies were messy, and generated serious amounts of heat in the curing process. A few years later, a clear resin gel eliminated much of the heat, but was difficult to work with, and was difficult to mold if you wanted to model rough or choppy seas. Recently, there is a new product in the model railroad hobby that comes in plastic bag, in the form of clear beads, that requires melting on the stove, then pouring onto the base. The drawbacks here are obvious, as plastic and resin are sensitive to heat.
Enter Acrylic gel medium...Acrylic gel medium is available from any art supply store. I prefer the clear, but you can experiment with different colors. I prefer the Liquitex brand, it comes in a large toothpaste-like tube, and has the consistency of toothpaste. The method of application is the same whether you require a smooth surface or choppy, rough seas.
I start by painting the base an overall flat blue-green. I then glue the hull of the ship to the base, and build the model, using the base as working platform. This wworks out real well, as it prevents my handling of the ship itself, and eliminates my big fingers crushing the PE and getting fingerprints on the model. Once the model is completed, I touch up any areas on the base with the blue-green base. Depending upon the ship, I sometimes mask the side of the hull with blue low-tack masking tape, this prevents any gel medium from getting onto the hull. Squeeze a small amount of gel onto the base, and even it out, leaving enough gel to cover the base surface. Work the gel up to the hull of the ship, and around the bow. A little heat from a hair dryer will speed up the process, the gel will turn an opaque white, like half-dried white glue. At this point, go back and reapply gel to the areas you want to build up, bow waves, wakes, etc. Go after the gel again with the dryer until it turns opaque white. If you desire rough, choppy seas, stipple the gel with a flat paintbrush. If you get the gel on the hull of the model, it can be removed with a cotton swab and some rubbing alcohol. For heavier seas, you may have to go back and repeat the last few steps over until you get the desired results. Gel can be built up upon itself as many times as you require. With repeated applications of gel some dramatic effects can be achieved, such as bow waves and heavy seas.
Once the gel has dried and stippled to your liking, it�s time to start painting and drybrushing the water. Apply a thin coat of the blue-green base coat to the top of the gel, dry-brush a lighter blue on top of the base coat, then drybrush a blue-white or green-white (depending on which ocean you�re in) along the tops of the waves, the bow wave, along the hull, and in the wake. The amount of white you add is obviously proportional to the speed you ship is making. A lot of white along the hull and wake implies you ship is under way, while little or no white implies your ship is either at anchor or all-ahead-dead-slow... I recommend experimenting with this method and developing your own preferences. Once the gel is dried completely, drybrush the 'water' with clear gloss or Future Floor Wax to give you the shine effect.
The beauty of gel meduim is its ease of application, the ability to build up layers, and the lack of odor, heat, and its ability to take paint. It's is easy to use, mistakes are easily repaired, it dries rock-hard, isn�t sticky like resins, and is relatively inexpensive, with a single tube costing $10-$15. Once tube is enough to do anywhere from 5-8 1/700 ships with average size bases, depending on how crazy you decide to get with your waves, etc.
Water by Jim Baumann:
Realistic Water in 1/700 and 1/350 Scale
In 1/700 scale I use Artists Watercolour paper which has a regular indented texture(try Winsor & Newton); firstly I cut the waterline profile out of the paper 0.5mm larger,this is done by placing the hull on paper and drawing round the hull with a sharp pencil ( before I even think about building the ship) then I stick to the base with eiter white glue or doublesided sticky tape. Build ship to the stage at which you are no longer happy to handle the ship,I ususally nount the ship in her sea before put on funnels or masts or photoetch. The ship is placed in the prepared cutout and screwed thru the base so that if it is a resin ship it prevents her warping. I then paint the sea in chosen base colour I add ships wake and bow-wave for (slow speed ) from white/PVA glue and build it up in stages. For medium speed I use Artists Acrylic gel/texture agent and shape it as it is drying. For a ship at high speed I use autobodyfiller for big wake and waves because it sets quickly (30-45 minutes!) so that I can carry on modelling!
In 1/350 scale if the ship is being shown in bigger waves I again use all the above techniques but glue the paper over bits of scrap wood to give the shape of the waves (remember to keep the wood bits clear of where the ship will go....) when the ship is finished ready for varnishing then I paint and drybrush the wakes and bow-waves, this is best left till last as the handling of the base will otherwise make the white go yellow....
I have also used succesfully white toothpaste(!) to really highlight white wavetops etc. cotton wool can be sued but do not use too much or the ship will look as if she is on a cloud....
