Would like again to ask for your expertise with the question I still have in my head: do you prime small parts, esp. superstructure when building? I am concerned with 1/350 scale as there will be always differences for 1/700.
I prefer painting during built - I still can not imagine how it is possible to paint everything after the ship is fully assembled and not to ruin anything.
So when working on superstructure I prepaint the lower deck (linoleum and grey) and then move to the next deck. Normally I shall prime each deck (and other parts) before painting - but I am tempted not to do it, esp. if I have very small parts to be painted separately - just paint them without priming to speed up. Also decks on superstructure are normally visible from top and from bottom - since they are hanging one over the other. So if I "follow the rules" both sides shall be primed which will take 1 extra day for each side to dry
How do you handle priming, esp. when building those IJN pagodas and the like.
Do some of you pre-prime parts when they are still on sprue and then sand out the areas which will be glued to have firm glue seams?
Thank you in advance.
Yevgeniy
