I've decided to build a air barge used by the Reds which was called Kommuna, as it is the only one on which enough information is available.
as I did on my previous scratchbuild of monitor Udarnyj viewtopic.php?f=13&t=34939, I laminated the scaled down plan on a piece of plastic and then after impregnating it with superglue I lightly sanded it to get it smooth and laminated the necessary thickness of plastic on the bottom.
After that I started adding details, of which there weren't a lot:
Since the barge didn't have an engine I decided to scratchbuild a tugboat for it. There isn't a lot of the information available on the tugboats used on the Volga river at that time sot I decided to build a generic one basing my information on one for which the information is available - a gunboat Vanya-Kommunist which was a converted tugboat.
The tugboat was build using the same principles as the barge:
That's it for now, ahead is the fun of scratchbuilding four Grigorovich M-9 biplanes
Vladimir
