If you have to paint your PE before installing it, is it a..
modelman62
..good idea to spray a dull coat on it so it wont maybe chip as easy?
Pat Hensley
mike mccabe
- Starling Models
HI Pat,
Partly depends on what scale you work in, I mostly do 700 scale so the less paint you have to put on the pe the better, more means thicker means less fine and in scale. I think if you clean it first, I just dunk it in hot water with a bit of washing up liquid, then rinse thoroughly, then you shouldn't need an undercoat.
That's what I do anyway!
Mike
Mike
modelman62
Thanks MIke, im doing 1/350 scale, doing the fletcher and Hasegawa Mikasamike mccabe wrote:HI Pat,
Mike
Pat Hensley
mike mccabe
- Starling Models
HI Pat
If you use an airbrush then you might want to do a couple of coats since the pe is larger and the thickness of the paint isn't such an issue. Sometimes it can be possible to wrap a little bit of masking tape around the tweezers when picking up the etch, it can help to cut down any chipping when you are assembling.
Mike
Mike
modelman62
Thanks again MIke !!!!mike mccabe wrote:HI Pat
Mike
Pat Hensley
RNfanDan
Also depends on whether enamel or acrylic paint is used...
When I use certain acrylics I've noticed a slight tendency for the paint to crack when bending and forming the PE. If you are painting the PE while still attached to its rack, and are using acrylic flat, I'd advise you to cut and form it first. This may not apply to all brands of acrylics, but it's been my experience. I've noticed this especially on small radius bends and corners. Your mileage may vary....
- Kelly Quirk
