model diorama
Rick
model diorama
Hey guys,
I have a diecast model of the battleship Yamato and will be getting the light cruiser Yahagi and 3 destroyers and I was just wondering how you would go about making a diorama.
What's the best material to use. I'm assuming I can use a plank of wood but what would be best used to replicate the ocean and the wakes of the ships?
Any advice would greatly be appreciated.
Rick
Rick
Rick
I live in a small town and I have yet to see an art store. Would foil paper spray painted in blue work well to replicate the ocean? I think I have a pretty good idea of what to use for the wakes. Perhaps a fine white powder would do the trick.
Anyway, if you have more feedback, it would be great. Thanks!
Rick
Rick
- johndon
- johndon
- 350z
The cheapest method is one introduced by Frank Isle. You paint board with acrylic paint and cover it with clear silicone from Home Depot. Here is my Slava on a such base.
Here is his article.
http://www.carrierbuilders.net/articles ... _Water.htm
- Francisco P. de Nanclares
I used Frank Ilse�s method too and got very pleasing results. This is my first attempt ever at building water:
It is quite easy and quick to build. I keep thanking Frank for his article, which pushed me to do it.
I will miss you Werner. Fair winds and following seas.- stu_fishing
also only can recommend franks method! easy, cheap and good looking!!
http://photobucket.com/albums/a336/stu_ ... 010118.jpg
http://photobucket.com/albums/a336/stu_ ... 010116.jpg
- 350z
- Rory Smith
I have tried a number of different ways to model water, celluclay, sculpey clay, gel medium and I always dislike it and try adding something else or starting over. I was eventually satisfied with the results of my 1/350th Missouri's water base seen in the gallery under my name. I started with a board with a blue base then tried the celluclay which is a form of paper mache, painted the celluclay and wasn't satisfied, it then cracked after drying so I applied gel medium over the celluclay for depth and then dry brushed over the gel medium with a really watered down sea blue and white for white caps. Do whatever you think will look good and just give it your damnedess.
" You can't dig a foxhole in a steel deck, but I damn sure tried." - History Channel
- johndon
Apologies for resurecting this thread but, having no acrylic gel to hand I've just tried a slight variation on Franks method and I have to say the results are the best water I've ever managed.
First, I crumpled tin foil into a ball and the flattened it out and stuck it to my base - this leaves plenty wrinkles in the foil to represent waves. Next, I cut out spaces for the ships, then painted as per Frank's method. I then added a coat of gloss acrylic varnish before adding the silicon again, as per Frank's method.
Still got to do the whitecaps and the wakes but it's a simple, effective method that also happens to be a LOT cheaper than acrylic gel.
John
John
