Hi, pretty new to this modelling thing, i m really doing it to practice my CAD skills rather than the actual modelling. Im modelling 1:400 Heller Tirpitz on Pro Engineer.
http://photobucket.com/albums/f310/mist ... bridge.jpg
shows my progress so far on the computer
and the actual model is looking ok but there is a big gap where the two halves of the hull don't meet correctly. Any suggestions on filling it in ? can i use poly filler or do i have to use something more advanced?
Many thanks
Filling in cracks
- Poppop
If there is a big gap, you're want to fill as much of it as possible with the plastic strip approach mentioned above. Fillers usually won't hold up on a large gap.
Then you can use the modelling putty of your choice to give you a smooth finish.
You can also use medium or heavy CA glues by applying it to the seam, hitting it with accelerator, and then immediately sanding it smooth. Gives a glass like finish if you do it properly... practice on some old scrap or model before trying it on your new project.
Charlie
Charlie
