I'm almost finished with my 1/350 Bismarck and I need some help to finish her off the right way. All that needs to be done right now are the riggings and the main deck railings. I also need to dull coat the model and that's where I need some advice.
Should I dull coat the model before I put the riggings on? I'll be using some invisible nylon thread darkened with a permanent marker and I wanted to know if the varnish will shrink when drying. If that happens it will surely pull the masts out of alignment and
Any help and advice will be greatly appreciated!
