styrene to paper/card stock
Roman1
Does anybody have some experience with gluing styrene w/ paper or cardstock? Which glue will do?
- les
I'd try a glue for paper and peel the paper off after the part is built. Just use it for a basic template. Any glue that stuck to the plastic could be easily removed. I'd make several copies of the paper model and keep the paper model as a master.
- les
The lights just came on. You might try scanning the sheet and then printing it on clear decal paper. You'd have to put a clear spray on it. Cut the decals out, put them on the plastic, cut the pieces out and you've got the positions of the deck house or whatever in their proper place. You can get decal paper in 8 1/2 x 11 sheets.
