STEREGUSHCHIY Project 20380 at 1:72 scale
Post by Dave Wooley »
Well it�s time to come clean with the next scratch build and it is the new Russian OPV or corvette the Steregushchiy . Project 20380 is quite a different warship from the warships of the Soviet era in incorporating many stealth features in to the design and western build technology and practice .
Steregushchiy Project 20380 Image
Builders model Image
General data
Length overall 93.9 m
Length at WL 84.6 m
Beam at deck 13.0 m
Depth at the fore 9.4 m
Depth amidships 7.8 m
Depth at transom 7.8 m
Full displacement ab.1900 t
Maximum speed 26-27 kts
Range at 14 kts cruise speed with full fuel stores 4000 nm
Endurance with maximum fresh water and provision stores 15 days
Crew, including KA27 PL team 90
PROPULSION SYSTEM
Twin shaft CODOG system, comprising:
......2x10,000 kW gas turbines
......2x3650 kW diesel engines
ELECTRIC SYSTEM
Basic power supply AC 380/220V, 50 Hz.
4x630 kw diesel gensets.
ARMAMENT
8xYAKHONT anti ship missiles in 2 vertical launchers
6xMEDVEDKA-VE anti submarine missiles in one vertical launcher
A190 gun mount 100mm caliber
2xKASHTAN-M close-in AA missile-gun system
2xMTPU pedestal mounted machine gun 14.5 mm caliber
SENSORS
Observation and target designation Radar system
Attack missile target designation Radar system
fire control Radar system gun
Two optronic fire control systems for AA close-in weapons
ECM Radar system
Chaff and decoy launcher system with four launchers
CO's electronic command console
Sonar system with hull mounted and towed arrays
Anti diver sonar system
OTHER EQUIPMENT
Active roll motions damper
Helicopter, hangar, flight deck
Launching/retrieving device for a towed sonar
________________________________________
[cross references | armament:]
AS-20 Kayak / SS-N-25 Switchblade / Kh-35 Uran
SS-N-26 Yakhont/Oniks P-800
SA-N-6 Grumble / S-300* Rif
AK 630
SA-N-9 Gauntlet / Klinok (Kinzhal)
SS-N-29 / RPK-9 Medvedka
I shall be looking forward to building the Kashtan M
The model
Having giving some thought as to the method of construction I've opted for a departure from the previous longitudinal plank on frame methods of construction I�m going to experiment with double diagonal. This method gives both light weight and a very strong hull. Using very thin timbers of only 0 .50 mm thick planks of marine ply. The first layer is applied at 40degrees from the keel then a second layer also at 40 degrees but in the opposite direction over the first layer . The only problem is having to provide for 10 or more stringers the length of the hull across and down each bulkhead. Although I have seen the results of this method I have to confess this will be my first attempt at double diagonal .
Running gear is ordered , timber ready so some cutting out can be undertaken. Reports may not be as frequent as in the past due to other contractual build commitments for the magazine .
At 1:100 scale the model measures
Scale 1:100
Length 1m 40mm
Beam 130mm
All the timbers prepared
This project has been in the planning stages for over 12 months and I have been very much looking forward to making a start . Thankfully being an OPV/corvette the hull at 1m 40mm is very manageable in my small workshop So the next job is cutting out all the bulkheads , laying the keel then into uncharted territory !!!!!
Re: STEREGUSHCHIY Project 20380 at 1:100 scale
Yay! :woo_hoo:
ARH
Post by ARH »
Sounds good Dave, :thumbs_up_1: :thumbs_up_1:
Simple but effective.
russclark
Post by russclark »
right on dave,not quite sure on what you mean about the extra stringers ,but when you are doing it my brain will fiqure it out :thumbs_up_1: .what was the launch date of this ship,the pic of the book says 2005 but that can't be it?.realy looking forward to your posts.i have been on the forum for about 5 or 6 years, and have learn't so much stuff i find myself forgetting alot :big_grin: .with a.r h,bill and yourself plus many others ,one has not far to look to find a answer to anything one needs to know :wave_1:
gingyer
Post by gingyer »
Looking forward to seeing this build Dave
looks a very interesting model
Colin
Scottish Model Warship Assoc.
carr
Post by carr »
Yes!!! Can't wait to see this one develop. :thumbs_up_1:
You know, this would make a pretty respectable LCS; better than the U.S. Navy's, at any rate.
Do you have a set of plans or are you working strictly off photos?
Is that a variable depth sonar hatch cover hanging off the stern?
NorthSea
Post by NorthSea »
Great to see that you've started the build Dave! I'll be following it closely, especially the masterclass in Kashtan construction! :wave_1:
Thank you all for your interest in this project. Steregushchiy was laid down in December of 2001 and entered service in 2007 .These OPVs are part of a Russian drive to regain expertise in naval construction greatly diminished when the Soviet Union disintegrated and a need to stimulate exports of light warships. Apart from the small Gepard OPV the Steregushchiy is the first Russian developed warship having extensive stealth characteristics.
Carr
The drawings were produced by an naval architect friend who was familiar with the features incorporated into the Steregushchiy design and has produced an excellent "ship yard" interpretation of the lines and part of the superstructure . I say ship yard as there are numerous numerical reference not required on a model makers draught. As yet the drawing is incomplete as the final set pertaining to the foremast supporting the "Positive M-1 3D air search dome are not as yet unavailable to reference . This I am told is a very complex shape to reproduce. These are just a few of the pictures which highlight the issues involved in creating a credible drawing of the foremast that will work for model making! As mentioned I've been keenly interested in developing this project for over 2 years from the moment I first saw Steregushchiy I thought that's my next scratch build project, I firmly hope I can do the ship justice in model form.
Export varient project 20382 "Tigre"
Richard J OMalley
Post by Richard J OMalley »
That is one mean looking ship .Bet you can't waite to make some sawdust . :thumbs_up_1: :thumbs_up_1: :thumbs_up_1:
Sean Hert
Post by Sean Hert »
Very excited to see you've begun! :thumbs_up_1:
Sean Hert
GTDEATH13
Post by GTDEATH13 »
I will be watching this too... :thumbs_up_1:
NIKOS (NICK)
Bluehawk
Post by Bluehawk »
Hello Dave.
Great to see you've begun the build of Steregushiy.
I will watching this with great interest.
Currently Building: Krivak I 1/72
Upcoming: Udaloy I 1/72
Sovremenny (Type 956E) 1/72
Kirov 1/72
carr
Post by carr »
Dave,
Just from a cursory examination, I can see that the builder's model photo that you posted initially has several differences compared to the photo of the stern of the real ship. Just goes to show that one has to be very careful evaluating the accuracy of sources! Even a builder's model is suspect!
Can't wait to see this one grow! :woo_hoo:
MichelB
Post by MichelB »
She's my favorite modern frigate design, a very sleek and elegant vessel. I have the (now sadly oop) Gwylan models resin kit, and while she sticks out like a sore thumb between my predreadnoughts, she's a beauty.
Will be watching this build with great interest.
carr wrote:Dave,
Yes the picture depiced does not show the stern VDS gate but it's closer than you may think ,I'll stick to the photos anyway builders models can be notoriously vague .
But notice the shape of the stern is not as flat as the first picture would imply
Here the shape changes below the VDS gate .
Dave Wooley :thinking:
There is no such thing as an accurate model only degrees of interpretation .
DW
Capit�o Norbert
Post by Capit�o Norbert »
Hi Dave
very interesting project and clean lines.
i know this model will be a great model from you
i will follow this thread :wave_1: :thumbs_up_1: :woo_hoo: :woo_hoo:
NorthSea
Post by NorthSea »
Dave, nice set of photos. What's the function of the two squarish appertures either side of the VDS door? I see that they have very thoughtfully painted scale markings on the stern so that you can work out the size of everything. :big_grin:
Capit�o Norbert wrote:Hi Dave
Thank you Norberto .
NorthSea wrote:Dave, nice set of photos. What's the function of the two squarish appertures either side of the VDS door? I see that they have very thoughtfully painted scale markings on the stern so that you can work out the size of everything. :big_grin:
Hi North Sea The answer is I really don't know but I am open to any suggestions :heh: :big_grin:
callen
Post by callen »
Wow!
I have to (shamefully) confess I knew nothing about this ship before this thread. It's hard to imagine something more sleek and modern looking that isn't actually science fiction. Can't wait to see this one take shape. Also very interested in your construction techniques. Looking forward to it! :wave_1:
Pessimists see the world as it truly is...
Optimists change the world.
