HMS Belfast - 1/200 scratchbuilt static model
Edward Pinniger
Post by Edward Pinniger »
This is a scratchbuilt project I've recently started (May 4th). It is the RN Edinburgh-class cruiser HMS Belfast, the only large RN WW2 warship still preserved today (moored on the Thames in London), in 1/200 scale. I haven't yet decided whether to build the model as the mid-war fit (represented by the 1/600 scale Airfix kit) or the late-war/Korean War fit of the preserved ship.
It's not really in the league of some of the other scratchbuilt masterpieces here - it's "only" 1/200 scale and is a waterline static model. However it is my first serious scratchbuilt ship model so I didn't really want to start at the deep end! In any case I don't really have storage/display space for models more than about 3ft/1m long; this was my main reason for picking 1/200, I originally intended 1/150 or 1/96 but simply don't have the space.
I built a 1/200 Tribal-class destroyer a couple of years ago, I didn't have much experience or knowledge of ship modelling at the time, not to mention a lack of reference books, so the model isn't particularly detailed or accurate. I'll post some photos of it another day!
The hull shape was constructed by measuring the Airfix kit at 1cm intervals, then multiplying the numbers by 3 and marking them on 1.5mm styrene card at 3cm intervals. I then cut between these marks and sanded the edges smooth to create the deck (made in two parts, the forecastle break makes this easy to do), then wrapped strips of 1mm styrene sheet (4 in total) around this to create the hull sides. A simple process but gives reasonable results for a waterline model. The distinctive stern profile was added afterwards, and the bow (where the ends of the strips meet) was covered over to create a smooth curve. The armour belt is 1mm and 0.75mm styrene card, with filler putty added at the edges and sanded smooth.
Note that this is very much a "low budget" build and if possible I'll be building it entirely from styrene stock, metal wire + mesh, and spares-box oddments from other kits. I won't buying any aftermarket metal armament, railings, fittings etc.
The one problem with this will be the lifeboats and motor launches - not sure how I'll do these. I may use resin or metal casting for the Carley floats/liferafts.
So far, I have completed the basic hull and deck, I've added the armour belt but have not yet got round to other details such as portholes. I've also added the planking to the fore and aft deck. This is represented by 1mm textured styrene card.
Anyway, here are the photos of what I've built so far:
Two views of the hull.
Comparison with the hull of the Airfix 1/600 model. It's surprising how much bigger the ship is when scaled up by a factor of 3!
Hull with deck planking added.
Next stage is to add the basic superstructure (sidewalls and decks); detail will be added to these "in situ".
ARH
Post by ARH »
Looking good, looking forward to more updates. ARH :woo_hoo: :woo_hoo:
Simple but effective.
JWintjes
Post by JWintjes »
Looking nice, and I particularly like your approach to the project! :thumbs_up_1:
A question if I may - did you reinforce the interior with something (perhaps balsa blocks) or is it just styrene? In the pictures it seems to have quite a lot of stability.
Jorit
Edward Pinniger
I put reinforcing "braces" of thick styrene sheet at 3 points on the bottom of the hull, also I added a layer of gap-filler superglue/CA along the underside of the entire deck/hull join. The hull sides do have a fair amount of rigidity, as you say.
Progress on this model will be fairly slow (I'm currently concentrating on the Fletcher and Ding Yuan (the latter about 75% done)) - it'll take several months at least. I'll post more photos as the model progresses, currently I'm working on the turret bases (is "barbettes" the technical term for these?) and the lower superstructure.
If it turns out well I'll almost certainly build more scratchbuilt warships. Maybe even try building a R/C model though the lower hull will be a problem in this case!
Victorious
Post by Victorious »
Nice to see a large Belfast model being built, I spent a bit of time aboard her in the late sixties, when she was tied up in Portsmouth as part of H.M.S. Bellerophon ( three ships tied up together, as accomodation ships)
After that period, she was taken into refit for displaying at her berth in London. Pity that more ships could'nt have been saved like this. Can you imagine the Victorious alongside the Belfast, now that would be a sight to see.
Talking of size comparison, here is a 1/400 against my 1/96 Victorious.
Keep up the good work on your Belfast. :thumbs_up_1: :thumbs_up_1: :thumbs_up_1:
Edward Pinniger
The 1/96 Victorious is mind-bogglingly huge - looks like you could probably fly R/C aircraft from its flight deck (not 1/96 ones obviously)! A very impressive piece of work.
Though 1/96 is the standard shipbuilding scale, 1/72 might have made it easier to obtain all the Swordfishes, Fulmars, Martlets etc. you'll need for the flight deck!
I have the Heller 1/400 Illustrious kit (IIRC this was a sister ship of the Victorious - am I correct?) though it'll probably be a while till I get round to building it.
No more work done on the Belfast so far as I've been concentrating on the Fletcher and Dingyuan, the latter is 95% finished and should hopefully be in the Picture Post forum soon, the former is progressing quite well - I've added scratchbuilt sidewall detail to the aft superstructure and bridge, and have started work on the funnels and 5' turrets.
middle_watch
Post by middle_watch »
Nice to see that Airfix kit again, it was the first ship model I ever built and I still think the best Airfix ever did. I was at a car boot sale a couple of days after reading your post and saw the box for a �1, figuring it would do for the spares bin I bought it and was pleasently suprised to find it intact and ready to build.
One thing has always puzzled me about the kit and maybe someone can help: What are those peculiar oval bin things midships between the secondary guns? They do not seem to serve any purpose and are missing on the current version of the ship.
JIM BAUMANN
Post by JIM BAUMANN »
I think you may be referring to the gun-crew shelters..?
They were also a feature on HMS Sheffield etc
see here on my 1/350 build of the ' shiny Sheff'
Hope it helps
Jim Baumann
middle_watch
Kool! That makes more sense, thanks Jim, love the touch of the splinter pads!
Edward Pinniger
Haven't had time to do any more work on this lately, but now the Kearsarge is nearly complete I'll probably resume work on the Belfast (and the Fletcher) fairly soon. Next stage with the Belfast is to finish the deck planking and start work on the turret barbettes and the lower levels of the superstructure.
I'm also currently working on another scratchbuilt (or rather semi-scratch) model, it's a much smaller scale (around 1/700), and a rather earlier ship, but has at least one thing in common with the Belfast other than being a RN ship! I'll post some photos of the completed model soon - I'm currently about halfway through painting it.
