Brush V's Air
NigeUK
Brush V's Air
Post by NigeUK »
Hi All
I am wanting to return to modeling after an absence of about 15 years. My question is this; How can I get good results with brush painting as opposed to airbrushing? I can't afford to buy the all the equipment etc for a decent airbrush at the moment, so will have to brush paint everything!
Any tips on getting good/better results wouuld be muchly appreciated.
Thanks in advance!! :wave_1:
Rob
Post by Rob »
Plan your painting in advance so that you don't end up with areas you can't get a brush into.
Buy good quality brushes, there is no economy in buying a cheap brush. It will have coarser bristles, be more prone to losing the odd bristle into your wet paint and not hold it's shape.
I use Games Workshop brushes, you can find their shops just about anywhere in the UK.
Thin the paint, brush only in one direction and be prepared to apply several thin coats rather than one thick coat. A single thick coat can either sag or clog up detail.
Use a light brush stroke so that you don't "drag" the paint.
Above all, don't worry about experimenting to find what suits you best.
If I can help some more, feel free to drop me an email
rob_kernaghan@hotmail.com
Rob
Avery Boyer
Painting
Post by Avery Boyer »
I've brush painted all my modeling career (7 years...and counting), and have been able to create presentable models. I can't really add anything to what Rob said, other then that I prefer to use acrylics, because they're easier on my brushes and me. I use pollyscale and modelmaster acrylics paints, and have painted everything from plain gray to coimplicated dazzle patterns. The nicest thing about acrylics is they're easy to remove if you don't like the result.
NigeUK
Post by NigeUK »
Thanks!! You have both boosted my confidence! Also, having read through some of the previous posts, airbrushing looks like a major hassle compared to a good old simple brush!! All that talk of different air pressures, needles, airlines . . . . . scary stuff!!
I guess I was worried about not being able to get nice uniform coverage on the large expanse of hull. Ship modeling is new to me (previously used to do aircraft - but that was 15 odd years ago or more!!)
kevinb120
Post by kevinb120 »
you can always use rattlecans too :thumbs_up_1: Tamiya's laquer sprays are fantastic. You can also use decal color sheets too, and even sharpies for quick touch ups, fine tip pens do engraved bridge windows, etc....
of all the things I've lost, I miss my mind the most
....I think the carpet monster got that too!
mike mccabe
Starling Models
Starling Models
Post by mike mccabe »
Nige
Those are wise words from Rob, you can get excellent results with brush painting, with any painting of ship models it is a question of planning and patience. Choice of paint is also an important factor, if you have been away for 15 years then you will be amazed by the quality of acrylic paint now but some brands can be difficult to brush paint. I would suggest stick with enamel for now, good old Humbrol is in my opinion the best paint for brush painting and they have a very wide choice of colour readily available. If you aren't sure about the particular colour you need then just ask on the board.
Any ideas on what you want to build?
Mike
JIM BAUMANN
Post by JIM BAUMANN »
welcome to ship odelling NigeUK!
I have always brushpainted all my modelships.;as an object ships lend themselves as a subject much better to brushpainting than an aircraft where uniformity of finish can be essential....
I have copied and pasted here for your convenience my contribution to the HOW_TO section right here at MW.com--see title page!
Rob K's points about multiple coats are very valid--patience is the name of the game!!
You can see the results of my brushpainting here:
good luck
Jim B
Jim Baumann's Tips and Techniques
Weathering Ship Models
by Jim Baumann
Most of my weathering/shading is actually done with wet washes of various colours. For example; If I have a light grey/white ship it is often difficult to give the ship a real 3-dimensional feel, as the various planes tend to blind/blend and as a result 3-D structures can appear very flat.To alleviate this on an angular turret for example, I brush down the appex of the angle the side of a PENCIL lead... This physically seperates the planes and provides a sense of visual depth!
Most early ships were coal fired and as soon as they were at sea will have produced copious quantities of soot, which deposits just about everywhere, when ship was hosed down or shipped spray/green water, this soot would have been carried along to scuppers/drains and would in short time have produced streaking down hull sides, this I simulate with dark grey wash streaked down slightly aft of vertical(apparent wind created by ships speed..!)
For darker grey ships I actually paint adjacent planes in different shades of the same colour to create depth and false shading, still using the pencil trick to differentiate planes. Streaking off portholes and scuppers is often done by sticking pencil in porthole recess,twisting slightly to create carbon deposit along the lower edge and the smudging down with finger; if the effect is too much paint with drybrush in vertical streak pattern using hull colour.
I personallly HATE the dark/light VERLINDEN method of drybrushing, it creates TOO much depth and makes the ship look like an AFV model or a TANK!!! I always wash the decks with watercolours, if I dont like the effect I can just wash away with good 'ol water. Putting the slighest hint of dish soap in the paint wash breaks up the surface tension and the wash flows more evenly. When I first paint the deck I use thinners and dark grey wash to create the caulking simulation, at the outset the condition of the deck needs to be considered when the build commences...
Realistic Water in 1/700 and 1/350 Scale
In 1/700 scale I use Artists Watercolour paper which has a regular indented texture(try Winsor & Newton); firstly I cut the waterline profile out of the paper 0.5mm larger,this is done by placing the hull on paper and drawing round the hull with a sharp pencil ( before I even think about building the ship) then I stick to the base with eiter white glue or doublesided sticky tape. Build ship to the stage at which you are no longer happy to handle the ship,I ususally nount the ship in her sea before put on funnels or masts or photoetch. The ship is placed in the prepared cutout and screwed thru the base so that if it is a resin ship it prevents her warping. I then paint the sea in chosen base colour I add ships wake and bow-wave for (slow speed ) from white/PVA glue and build it up in stages. For medium speed I use Artists Acrylic gel/texture agent and shape it as it is drying. For a ship at high speed I use autobodyfiller for big wake and waves because it sets quickly (30-45 minutes!) so that I can carry on modelling!
In 1/350 scale if the ship is being shown in bigger waves I again use all the above techniques but glue the paper over bits of scrap wood to give the shape of the waves (remember to keep the wood bits clear of where the ship will go....) when the ship is finished ready for varnishing then I paint and drybrush the wakes and bow-waves, this is best left till last as the handling of the base will otherwise make the white go yellow....
I have also used succesfully white toothpaste(!) to really highlight white wavetops etc. cotton wool can be sued but do not use too much or the ship will look as if she is on a cloud....
Painting Decks on Ship Models
I used to (and still do) use MATT RADOME TAN by HUMBROL paints or TEAK by COLOURCOATS from WHITE ENSIGN MODELS this is brushed on ,when dry I overbrush again sparingly using the same paint mixed with mid grey, same again using deck colour mixed with light grey,always sparingly, almost dry, brushed on fore and aft only. THEN WHEN TOTALLY DRY and not a second before I make up a mix of Dark grey/black and thinners and wash the the deck down; this gives an impression of the caulking effect as it settles into cast on/moulded deck detail. If the planking detail is raised I use a pencil lead from a self-propelling pencil dragged across raised lines(ICM 1/350 Koenig for example) This mix MUST be very very thin, DO NOT overbrush it or the paint sediment will get brushed out, the thinners will soften the paint, and bingo, one wrecked deck.....Once you have washed with thinners hold model under lightbulb or heat source so that the thinner evaporates quickly, take no risks with softening paint. IF IT DOES wrinkle slightly DO NOT touch it .When DRY you should be able to press it flat and carry on the with build.
Painting White Ships, Painting Black Ships
For White hulled ships I have painted the base coats with revell matt white as this has VERY good covering power in one coat; unfortunately it is a little creamy and therefore not crisp enough. I overcoat two thinned coats of Humbrol to give a crisp "brilliant" white without too much paintbuildup obscuring fine detail.Most ships of this era were coal burners and even sitting at anchor with a small heaad of steam they were (in my opinion) producing sooty smoke, particles of which would land on the decks etc and even with regular scrubbing and hosing down would streak off from scupppers etc. As a result I streak the hull gently allover with a light shade of grey wash in a vertical plane, accentuating near anchors and natural water collection points.If I feel I have overdone it I "restreak" in white in shade of choice to lighten the picture; as I do not build "Dockyard " models the above is only from my experience of building ship models in an underway situation( when there are presumably more funnel emissions...!)
For Black Hulled ships(inc liners) I have always used a matt true black and then washed down( often) with watercolours in shades of grey(use distilled water to prevent limescale stains in hard water areas!!) with localized drybrushing in light grey or if the area has been highlighted already(around door/armour plate etc) to give sense of depth I use a very sharp very soft pencil to gain a crisp dark line to seperate the highlight from base structure(essential to overcoat with clear flat!)
I think I should mention that I do all my painting (except the flat varnish coats) with a brush by hand......
This is only a short summation of what I do to produce the effect that I BELIEVE to look lifelike and convincing and that I BELIEVE is borne out by contemporary photographs of the period.....( this is my disclaimer!!)
Rigging and Masts
I use ONLY scratchbuilt masts made of Steel/brass wire. For tall masts in 1/350 I use syringe needles, as a tube structure will not bend under tension in the sameway as a rod structure. When you make cage arials (Panay and Dreadnought etc) out of Ladies stocking lycra thread the cumulative tension is large and will pull masts out of line; even the shrinking of sprue with smoke will pull wire masts out of shape, always attach shrouds well, in model form they actually have a function even in sprue!!!
For all of my rigging (see some other ships of mine posted in the Modelwarships.com gallery) I use stretched sprue; the trick is to use the RIGHT kind of sprue. I have always found great success with AIRFIX CLASSIC SHIPS (sailboats,old,large..) in particular an HMS VICTORY that I have been melting down the sprue runners on for years; when I run out I will start on the yard arms, by my retirement I may start melting the masts... The main feature of this plastic is that it is BLACK, it requires no painting, hence keeping it thin and light.
Here is my method:
Light end of sprue runner until it just catches flame, blow out and dab one end onto piece of paper/card on workbench and slowly but firmly pull until the desired line thickness is achieved.The trick is to pull initially real fast to get it thin, then as the plastic cools, slow down the speed of pulling
If you are going to need LOTS, set up two paint tinlets on bench, and follow the procedure above but when you run out of space simply bend it around the paint tinlet and continue on till plastic cools and your thread breaks. You will need to practice a little to get consistently thin sprue. Black sprue is THE cheapest modelling material we will ever use pro rata, so if you are not satisfied with result simply discard it and start again.
To rig, use a small pool of liquid cement on bench, dab the end of chosen rigging piece in cement and with tweezers attach to ship/yard let set for 5-10 seconds and draw the other end to your chosen attachment point. Dab on a minute amount of liquid cement and draw the sprue piece thru the cement and let set. With liquid cement on the end of a toothpick, melt the plastic of the spruee and voila you have a neat attachment with no furry ends or scissors etc
Having rigged some shrouds for example you may wish to tighten them. Hold model over a consistent smoke source such as inscence or cigarette (I gave up, hence joss sticks) and the hot smoke will tighteen the rigging like magic.My advice is take a very old/scrap model and practice as it is very easy to completely rig a model and then at the tightening stage get too close to heat source and completely UNRIG the model.... with resultant fury, frustration and vulgar language...!!
NigeUK
Post by NigeUK »
All really helpful - thanks!!
I am currently just starting building the Airfix Vosper MTB in 1:72. It is not the best of models (compared to say Tamiya) but it is testing out all the old skills i thought I may have lost, and I am quite enjoying it!!
The main skill i think i have picked up is Patience!! 15 years ago i wanted to complete the model as quickly as possible, as there was always something else in the shop i wanted to buy!! Now I feel I can take my time - if it takes me a year to finsih it - doing a little each week thats fine by me!!
Once again- thanks for all your tips etc. I will most likely sign up to the forum now - don't want to be a 'guest' anymore!! Keep an eye out for me!!
Cheers all! :rolf_3:
