When I first started this picture i was thinking it would end up in the junkyard, but as it started commimg along its getting better and better (IMO). This picture is a lot closer and alot more detailed than my previous picture (First pic in my CSGN-138 post). If i can pull it off it will be my best one yet (again IMO). This one has really sucked me in and Ive been on it over three months now.
FlightII will have the gun mount moved forward of the VLS. The VLS is also a new design. Instead of two MK-41 (which would take up alot of space above and below decks) i have "designed" a new one that looks to be about three times the cells of the MK-41 (one of these days when im really board ill try to count them
So, this is the Digital picture i will use as a background. I will also be stealing stuff off this ship for mine.
below is the Virginia "template" I will use. It is one of my "analog" modified pics. I will cut this pic out and reverse it so its going the right direction for the new pic.
I then start adding the stuff i need from different pictures.
in the below pic i have done a lot of blending. I had to start over on alot of things because i was folling the lines from the "template" picture, which are just a tiny bit off from the burk picture. Just enough off to make everything screwy when you would look at the pic as a whole, so i got the lines off the burk pic and fixed everything. This is as far as i am for now. Ill post progress as i can.
