Why?
DeadByCheese
Why?
Post by DeadByCheese »
Well, the testors enamel black and brown paints on really nice without thinner. When it dries, it looks like the part is made of brown/black plastic and wasnt painted.
Yet the WHITE testors enamel paint is patchy and you must put on multiple coats with a brush to get it all evened out. Really annoying for IJN aircraft like the zero.
Noob Modeler
Current Projects
- 1/350 Yamato
- 1/700 Hyuga
Wants/Future Projects
-1/350 Nagato
-1/350 Yukikaze
-1/350 Akagi
Yeah, white anything is pretty much impossible. 3 or 4 coats are not uncommon to make it look decent.
kennylibben
Post by kennylibben »
...tell me about it.
Ron Smith
Post by Ron Smith »
If I remember correctly they took the lead and benzene out of paint before you guys were even dirty thoughts. Enamels with benzene airbrushed & handbrushed better and cured faster. Paints with lead, especially white, yellow, red and orange actually covered in one coat.
Now you know why..........
Narggggggggggghhhhhhhhhhhh!!!!!!!!!!!!!!! Cursed environmentalists! What's wrong with benzene anyway?
Post by Guest »
Timmy C wrote:Narggggggggggghhhhhhhhhhhh!!!!!!!!!!!!!!! Cursed environmentalists! What's wrong with benzene anyway?
Serious carcinongen.........
kennylibben
whats not these days?
Ron Smith
Post by Ron Smith »
kennylibben wrote:whats not these days?
That was me....oops...........
Benzene was one of the first products pulled from the consumer market for carcinogenic reasons back in the 1970's. It is one of the truly nasty carcinogens and while still used industrially it really should not be in consumer products (remember, some bright individual caused Husqvarna to put the warning label on their chainsaws "DO NOT attempt to stop moving chain with hands and/or genitals).....do you really want one of those bright lights handling something as nasty as benzene in or near your home?
largeallan
Post by largeallan »
WITH GENITALS!!!!?....I bet you wouldn't try that more than once!!! :lol_1:
RNfanDan
NONE
Post by RNfanDan »
(removed for the sake of the children)
Rob
Re: Why?
Post by Rob »
DeadByCheese wrote:Well, the testors enamel black and brown paints on really nice without thinner. When it dries, it looks like the part is made of brown/black plastic and wasnt painted.
I assume you have brush-painted onto bare plastic?
Not that I use the same brand, but next time, maybe you would be better either priming first or just using an airbrush.
Washing the plastic with a small amount of washing powder before you build can also make a difference, but make sure the water isn't too hot.
Now you have got to the stage of the dried paint looking greasy, what you could do is apply a wash coat of the same colour over it.
Brushing white it is difficult to get away from the problem, other than patience and a lot of thin coats.
Hope this helps?
Rob
Ron Smith
Post by Ron Smith »
RNfanDan wrote:Why....
Yet again, we have an accurately-titled, informative, relevant, and clearly descriptive subject header....
Well actually the header was more relevant and informative than your rant and the thread stayed on the intended topic right up until said rant.
RNfanDan
Post by RNfanDan »
Oh, okay, I get it now---The word "why" is VERY descriptive, you're right, so sorry, obviously it was just my foolish mistake! The topic being discussed is SO clearly indicated by the header line! I don't know why it wasn't clear as day to me. Why, I must have been referring to another post, entirely!
The next time I see a subject header with the single word, "Why?", I will IMMEDIATELY know right away, that it refers to paint color, adhesion, coverage, etc. Why would I think otherwise? Thanks for the reply, Ron....oops! well, time's short and I gotta go now, I have to mask and spray-why the lower hull of my destroyer model.
--Dan
P.S.: I'm using a brand-new jar of why, in a hull red I just got last month...I'll let you all know the results in a separate post! It'll be titled "Why!"instead of "Why?", so everyone will know exactly what my post is about.
Dan, take it easy on the new guy, ok? He's just starting out in the hobby.
kevinb120
Post by kevinb120 »
Best way to do white is to only use spray(cans). Tamiya ultra fine white primer and Tamiya flat spray white laquer is all you need. Two mist coats of primer, one finish coat of matte white. The laquer based paints cover well, dry extremely fast, and are nearly impervious to any chemicals, washes, or decal solovents. Every white bottle paint is too tempermental to waste your time with them, and often take weeks to fully cure. Don't waste your time. I can get black plastic perfectly white and dry in 20 minutes including all three coats with the spray. Being laquer it also is compatible with every other type of paint. I've had the two cans of spray for about 10 different model's radomes, landing gear, armament, etc. White spray enamel like Model Master's or regular Testors is NOT the same thing and has the same problems as bottle paints.
of all the things I've lost, I miss my mind the most
....I think the carpet monster got that too!
RNfanDan
Post by RNfanDan »
Timmy C wrote:Dan, take it easy on the new guy, ok? He's just starting out in the hobby.
Well, to be honest, my original post here was just in fun, even IF I was the only one "laughing". I had just yesterday (I thought?), nailed-up a more serious post on this very issue (subject/header relevance); and here I am already, only hours afterward, stumbling across yet another one! Hence, my "friendly reminder" of today.
Evidently, nobody "got it", but my reply to Ron's contention that this thread was...
a) relevant, and
b) on-topic until I posted,
....was clearly not aimed at the "new guy", Timmy.
Everybody take a happy pill and call me on September 31st if not feeling better! :heh:
Meanwhile, I'm learning all about the whys and wherefores, so please---carry on!
:lol_spit_1:
klein loewietje
Post by klein loewietje »
Dan, if I'm not mistaken, this treat was posted about 12 hours before your 'don't you just'- post.... :big_grin: :big_grin:
Sorry, couldn't resist!! :rolf_3:
Greetz, Johan
VENTIS SECUNDIS
253 269 863 261 471 958 220 370 4 21 19 24
Alrighty then, Dan =)
It's just that I had thought your first post in this thread was aimed at DBC, who posted the title.
Ron Smith
Post by Ron Smith »
Actually I'm objecting to a pointless RANT inserted into a thread that was going reasonably well. I'm not real keen on netiquette cops where no malicious intent was meant by any of the parties in a thread......but hammer trolls and anonymous snipers all you like since their intent is malicious by definition.
RNfanDan wrote:
Ron Smith wrote: Well actually the header was more relevant and informative than your rant and the thread stayed on the intended topic right up until said rant.
--Dan
Rob
Post by Rob »
Ron, I agree with you, I cringed when I saw Dan's post.
Rob
