Cutting plastic rod
Mike Coleman
Cutting plastic rod
Post by Mike Coleman »
This may seem like a simplistic question but it is a problem that has been vexing me for years. Whenever I cut a length of plastic rod I have a terrible time getting a straight 90 degree cut. I have tried the "Chopper" and that is graet for angled cuts but not 90 degree. Other than putting it in a pin vice and cutting straight across the collett - which is very time consuming - does anyone have a trick that I ahve not thought of? I thank you in advance for any tips.
Mike Coleman
Ron Smith
Re: Cutting plastic rod
Post by Ron Smith »
Mike Coleman wrote:This may seem like a simplistic question but it is a problem that has been vexing me for years. Whenever I cut a length of plastic rod I have a terrible time getting a straight 90 degree cut. I have tried the "Chopper" and that is graet for angled cuts but not 90 degree. Other than putting it in a pin vice and cutting straight across the collett - which is very time consuming - does anyone have a trick that I ahve not thought of? I thank you in advance for any tips.
Mike Coleman
Assuming it's truly round or close to it simply rolling it under a single edged razor will score it enough to snap it off. If you roll it straight the score should be a perfect 90 degrees.
