Wave Formed Sheet
veliko_pile
Wave Formed Sheet
Hi,
I really love the way that this seascape looks:
http://www.naritafamily.com/howto/Misso ... _frame.htm
But I can't find anywhere this Wave Formed Sheet, do anyone know where I can buy it, or if anyone have some spare I'd like to buy it.
I think that this is the most realistic way to do a big scale sea, so I would like to try it out
Russ2146
Re: Wave Formed Sheet
I think that you misunderstand what is being done in this build.
He did not buy a "wave formed sheet".
He created the waves by using a product called Liquitex, an acrylic gel, to sculpt the waves on a base of wood sheet, painted and topped with plexiglas to which he applied the Liquitex, sculpted the waves, applied more paint and then the white foam, which is also an acrylic gel.
NukeMM
- Back-Aft Models
I kindly disagree with you, Russ. The gentleman actually applied Liquitex to the wave formed sheet and peeled the curred Liquitex gel off of the sheet and used the solid Liquitex.Russ2146 wrote:I think that you misunderstand what is being done in this build.
That's how I understood the process, anyway.
Carl Musselman
(Formerly Back-Aft Models)
Photobucket
YouTube Channel:
Photobucket
YouTube Channel:
veliko_pile
He applied the liquetex gel on the wave sheet, whet that was dried he pulled off the thin layer and used that layers to make the actual sea.
I don't have a preformed plastic wave sheet, so in order to do this process I need to buy ONE at least (than I can make layer of GEL out of it). So my question is where to find (buy) this preformed sheet, I did understand the process
Russ2146
OK, now I see it
Dang!!!! Now I'm getting frustrated looking for it!!!!
Tamiya made it in several versions a few years ago; TamiyaUSA still has it listed, so might have it available? http://www.tamiyausa.com/product/item.p ... t-id=89673
Look for Ocean Effect Plate.
Russ2146
Both Hobbylinc http://www.hobbylinc.com/prods/sja_tam.htm and
Hobby Search http://www.1999.co.jp/eng/10047619
are out of it. Looks like Tamiya hasn't produced any more.
veliko_pile
The guy that made the Missouri diorama spoke of some other brand, maybe someone else is producing something similar
Russ2146
I tried that as a brand but didn"t come up with anything and if you look at the packaging he shows, it looks a lot like Tamiya's packaging.
Plastruct makes a similar product, though Tamiya's looks better, I think, for open ocean.
http://plastruct.com/Pages/OnlineCatalogIndex.lasso
WPRB-608 BLUE STORMY WATER SHEET 91804 COMPLETE
WPRC-608 CLEAR STORMY WATER SHEET 91814 COMPLETE
WPSB-208 BLUE CALM WATER SHEET 91801 COMPLETE
WPSB-208XL BLUE CALM WATER SHEET 91821 COMPLETE
WPSB-308 BLUE AGITATED WATER SHEET 91802 COMPLETE
WPSB-308XL BLUE AGITATED WATER SHEET 91822 COMPLETE
WPSB-408 BLUE CHOPPY WATER SHEET 91803 COMPLETE
WPSB-408XL BLUE CHOPPY WATER SHEET 91823 COMPLETE
WPSC-208 CLEAR CALM WATER SHEET 91811 COMPLETE
WPSC-208XL CLEAR CALM WATER SHEET 91831 COMPLETE
WPSC-308 CLEAR AGITATED WATER SHEET 91812 COMPLETE
WPSC-308XL CLEAR AGITATED WATER SHEET 91832 COMPLETE
WPSC-408 CLEAR CHOPPY WATER SHEET 91813 COMPLETE
WPSC-408XL CLEAR CHOPPY WATER SHEET 91833 COMPLETE
WRFB-5 BLUE WATERFALL 1-5/8" WIDE 94611 COMPLETE
WRFB-10 BLUE WATERFALL STREAM 1-5/8" WIDE 94616 COMPLETE
- reigels
Looks like Tamiya "Ocean Effect Plate A" is still available at Lucky Model:
http://www.luckymodel.com/scale.aspx?item_no=TA%2089673
I bought a few of these at HLJ a couple of years ago and they're pretty good: rough surface on one side and light wave pattern on the other. Was about twice the size I was expecting when it arrived. Get it where you can since they seem to have been discontinued.
Alternatively you might want to check your local home improvement store. Clear plastic diffusers panels for fluorescent lights sometimes can be found with a suitable wave pattern. Something like this: http://www.homedepot.com/webapp/wcs/sto ... =202653804 is only $5.00 a sheet.
See also: http://www.modelwarships.com/features/h ... ature.html
-- Scott
Russ2146
Lucky Model shows it as "Available", which in Locky Model Speak means "We don't have it in stock but we'll take your order and ship the product to you and bill your credit card, when it comes in. Just don't hold your breath."
The two Japanese links I posted show it also but indicate that its not in stock
veliko_pile
exactly, Lucky model "available" status means just that....But, I'm just wondering, I need this for a 1/350 A/C carrier, all this sheet are presumably for 1/700 scale, would it be "out of scale" for a 1/350 ship?Russ2146 wrote:Lucky Model shows it as "Available", which in Locky Model Speak means "We don't have it in stock but we'll take your order and ship the product to you and bill your credit card, when it comes in. Just don't hold your breath."
- Pagodaphile
I looked at the Tamiya wave sheets some time ago and found them too small and expensive for the size I usually work with. My scrounger instincts finally kicked in and I found an acrylic sheet supplier.
In the West Coast, its Tap Plastics, which operates several stores from California to Seattle. These guys sell the stuff in large sheets in various thicknesses for privacy glass applications, commercial displays, table tops, etc. I discovered that these stores custom cut the stock to size for their customers. This then leads one to the left-over scrap material from the cutting shop and the wonderful "scrap box". Large (by model standards) odd-shaped chunks can be found here for bargain prices (compared to the price from our friends at Tamiya), if you are willing to nose around a bit. A few times each year you can find me "dumpster diving" in one of these stores.
I have found their "Lucerne" and "Insbruck" texture patterns to be useful for a starting point to simulate various wave patterns. By holding each piece at an angle to the light, you can see if it has the "wave" pattern that you are looking for.
http://www.tapplastics.com/product/plas ... ucerne/549
http://www.tapplastics.com/product/plas ... ucerne/523
veliko_pile
thanks for the tip, the "Lucerne" looks great, but I'm not from USA, so I cannot buy that, maybe here some shops have similar patterns
- Pagodaphile
Not sure where you are located, but if you go to their home page you can see all the various applications the stuff is used for. I would bet that there is some sort of supplier for the material near you.....Good Luckveliko_pile wrote:thanks for the tip, the "Lucerne" looks great, but I'm not from USA, so I cannot buy that, maybe here some shops have similar patterns
