How to weather using chalk
Frequently Asked Questions (Read only)
richter111
Post by richter111 »
Heres your requested info.
NEED THE FOLLOWING:
1. Dishwashing liquid
2. Artists chalk
3. Old bowl to mix items in.
4. Razor blade or Hobby knife
5. Cotton buds/Q-tips/toilet paper
6. Cup of water
First: In the bowl, scrape off a amount of artists chalk that you will feel needed for the job
Second: Add a 1 CM sized dollop of dishwashing liquid to the center of the chalk. Then add a small amount of water.
Third: Mix well making a chalk slurry of the above ingredients. Mix with a cotton bud, works well for me.
Fourth: Apply mixture to the surfaces that you want to dirty up. I reccomend applying to a glossy surface, as a dull finish will stain and is very difficult to erase mistakes.
Fifth: Let this dry for an hour or so.
Sixth: Wet cotton buds/Q tips/toilet paper (folded up into usable squares) and remove any excess around the lines or places that you don't want it. You can be careful and blend into unweathered areas with this method.
Seventh: When you have achieved desired results, allow to dry for at least a week, then spray gloss or flat cote on top to seal the weathering in
This should cover everything, any questions, just ask em here!
DISCLAMER: This works for me, it may not work for you and I wont buy you a replacement Nimitz if you goof it up.
Ric
ddp
Post by ddp »
aaawwwww!!! party pooper!!
Adam Leet
Post by Adam Leet »
Is there a specific brand of dishwashing liquid to use?
Anonymous
Post by Anonymous »
Great!
Thanks.... :jump_1:
richter111
NO any dishwashing liquid is fine, the liquid just adds a surfacant to hold the chalk in place.
William J
Post by William J »
interesting Richter, thanks for that.
Bill :smallsmile:
long live jazz :cool_1:
Keep The Faith Gentlemen and Watch the Offside
nurglespuss
Re: How to weather using chalk
Post by nurglespuss »
Or instead of waiting a week, you can use klear floor polish instead of detergent/water. It does exactly the same thing & seals in the chalk :> Just applied second coat after only 2 hours :>
Return to “FAQ”
