1/350 Warehouse & Dock 16" or 32" Option
NukeMM
Back-Aft Models
Back-Aft Models
Post by NukeMM »
NEW 1/350 Warehouse and Dock Sets now available for orders at BACK-AFT Models.
http://shop.back-aft.com/1-350-Dockyard ... es_c10.htm
I need one of these warehouse docks for the diorama that I am planning for my USS Barnegat class AVPs.
This kit depicts the Pier 2 warehouse dock at Norfolk Naval Base. It was built during World War II and still existed as late as the mid 1990's. I'm not sure if it still stands, today. My diorama will be dated about 1953.
I've designed this 1/350 model warehouse in resin and below is the test-fit of the first casting of parts.
The warehouse is designed to be built to any desired length ranging from 10" to 34" or more. For my diorama I'll only need about 15".
I plan to create the instructions for the warehouse's assembly while building the warehouse intended for my diorama. The kits will be available some time after that.
Carl Musselman
(Formerly Back-Aft Models)
Photobucket
YouTube Channel:
davidwaples
Re: Coming Soon from Back-Aft Models - 1/350 Norfolk Warehou
Post by davidwaples »
Very nice Carl. You're working on some very interesting projects.
Dave
Cadman
Site Admin
Site Admin
Post by Cadman »
Does it come with an interior kit with lighting????? :cool_2: Impressive work.
Timothy Dike
Owner & Administrator
ModelWarships.com
NukeMM
Back-Aft Models
Back-Aft Models
Post by NukeMM »
Assembling the 1/350 Warehouse.........
Step 1: Sanding the thin resin film from the back side of the walls to open up the windows. This must be done to the window sections and the overhead doors, as well.
Step 2: I recommend painting the wall and window sections and the doors before continuing with Step 3.
Step 3: Filling the windows with Micro Krystal Klear.
This requires placing clear packing tape on the back side of the wall and then filling the window panes with Krystal Klear. It will take at least two applications of the liquid. The same methods were taken with the window sections and the overhead doors.
Carl Musselman
Photobucket
YouTube Channel:
NukeMM
Back-Aft Models
Back-Aft Models
Post by NukeMM »
Step 4: Attach the overhead doors to the walls. The door pieces can be trimmed to portray open or half-open doorways.
Step 5: Attach wall sections together to extend the length of the warehouse. The doors act as tabs to join the wall sections together. Special tabs are included with open doorways in case the doorway at the walls' attachment points are desired to be open doorways. The seams at the joint of the wall sections will be covered with water downspouts made from .020" styrene rod.
Carl Musselman
Photobucket
YouTube Channel:
NukeMM
Back-Aft Models
Back-Aft Models
Post by NukeMM »
Step 6: Attach the end wall's door to the end wall.
Step 7: Attaching the side walls to the end wall. Right angled tabs are provided to square up the corners of the end wall and side wall joints.
Carl Musselman
Photobucket
YouTube Channel:
NukeMM
Back-Aft Models
Back-Aft Models
Post by NukeMM »
Step 8: Attaching the support walls to the side walls. These are to spaced so as not to interfere with roof sections joints that are attached to each other with tabs similar to the lengthened side wall sections.
Step 9: Attach the window sections together to match the desired length of the warehouse. These are assembled similarly to the method of attaching the wall sections together with the use of special tabs. The window sections are then attached to the end wall and the support walls. These seams will be covered by water downspouts, as well.
Carl Musselman
Photobucket
YouTube Channel:
NukeMM
Back-Aft Models
Back-Aft Models
Post by NukeMM »
Step 10: The upper roof and lower roof sections are lengthened to match the desired length of the warehouse with use of tabs to connect their ends together.
Carl Musselman
Photobucket
YouTube Channel:
NukeMM
Back-Aft Models
Back-Aft Models
Post by NukeMM »
Step 11: Attaching the lower roof sections.......
Carl Musselman
Photobucket
YouTube Channel:
NukeMM
Back-Aft Models
Back-Aft Models
Post by NukeMM »
Step 12: Cover the wall and window seams with water downspouts made from .020" styrene rod ....
Carl Musselman
Photobucket
YouTube Channel:
NukeMM
Back-Aft Models
Back-Aft Models
Post by NukeMM »
Step 13: Attaching the Upper Roof Sections and the Ridgeline.
The warehouse was glued to the completed dock from within before attaching the Upper Roof Sections.
Carl Musselman
Photobucket
YouTube Channel:
NukeMM
Back-Aft Models
Back-Aft Models
Re: NOW AVAILABLE from Back-Aft Models - 1/350 Warehouse & D
Post by NukeMM »
Carl Musselman
Photobucket
YouTube Channel:
NukeMM
Back-Aft Models
Back-Aft Models
Re: REDUCED PRICING: Back-Aft Models - 1/350 Warehouse & Doc
Post by NukeMM »
New, reduced pricing on the 1/350 Warehouse and Dock kits.
And Single Bollards (set of 16) included with Dock sections.
Carl Musselman
Photobucket
YouTube Channel:
CWO/MRC
Post by CWO/MRC »
Too Cool !!!
Pat :cool_1:
Pat Connors
rotley
Post by rotley »
Are Back-Aft Models still in business?
Post by Guest »
rotley wrote:Are Back-Aft Models still in business?
Something I've been trying to find out too. I heard there was a conversion kit for USS Half Moon, but cannot find, anywhere.
NukeMM
Back-Aft Models
Back-Aft Models
Post by NukeMM »
Does anyone know who "Guest" is / was?
I'd like to try and help with the Half Moon parts.
Carl Musselman
Photobucket
YouTube Channel:
NukeMM
Back-Aft Models
Back-Aft Models
Post by NukeMM »
I assembled a whole warehouse, this weekend. I had never done that before, just a short version.
I think it's pretty cool. I just use this one for display / prototype purposes. I found a few flaws in my sequence of instructions and sequence of upper window assembly. It was worth the effort.
Carl Musselman
Photobucket
YouTube Channel:
NukeMM
Back-Aft Models
Back-Aft Models
Re: Back-Aft Models - 1/350 Warehouse & Dock
Post by NukeMM »
I betcha my Dock is bigger than your Dock. :big_grin: :cool_2:
Carl Musselman
Photobucket
YouTube Channel:
NukeMM
Back-Aft Models
Back-Aft Models
Post by NukeMM »
NEW SHORTER WAREHOUSE OPTION - 16 inches long instead of 32.
A 16 inch-long warehouse with the option of a 21 inch-long dock is now available on my eBay store.
Ebay Listing:
https://www.ebay.com/itm/334203065716?h ... Sw~JhhgBN8
Carl Musselman
Photobucket
YouTube Channel:
