Crafting material
Killick
Crafting material
Post by Killick »
I'm building a 1:90 scale tall ship and I want to replicate the intricate carvings around the stern windows and quarter lights. I doubt that wood would hold the details properly, so I wonder what to use, resin or some soft metal, or something?
I would appreciate any suggestions.
biggles2
Re: Crafting material
Post by biggles2 »
Depending on what the fancy work looks like - is it scroll work? - I might try using pieces of lead, or solder, wire to form the shapes, glue them on with CA, then paint them. :wave_1:
merriman
Post by merriman »
biggles2 wrote:Depending on what the fancy work looks like - is it scroll work? - I might try using pieces of lead, or solder, wire to form the shapes, glue them on with CA, then paint them. :wave_1:
Renshape. https://www.freemansupply.com/products/ ... foam-board
Get the 40-lbs. stuff.
David
"... well, that takes care of Jorgensen's theory!"
Killick
Post by Killick »
Yes, stuff like that. Thanks for your advice.
Killick
Post by Killick »
David
Thanks for your help.
wefalck
Post by wefalck »
There are two different sculpting minds, the subtractive and additive ones. Subtractive minds prefer to carve from the solid, while the additive ones prefer to add material, as when working with clay. Decide which one you are and choose your material.
The classical material for intricate carvings is Boxwood or Castelo (the American variant of box).
For additive sculpting there are various polymer clays, two-part epoxies (e.g. Miliput White, Sculpey), or acrylic gels (which can be applied in layers with a brush). Once could think also of composite construction, e.g. laying out the scroll-work in wire or thread and then work it up with acrylic gel. You can also work on decal sheet and transfer the work later to the model.
Eberhard
Image Image Image Image
Killick
Post by Killick »
wefalck wrote:There are two different sculpting minds, the subtractive and additive ones. Subtractive minds prefer to carve from the solid, while the additive ones prefer to add material, as when working with clay. Decide which one you are and choose your material.
That's useful advice, thanks.
