Model Monkey Deutsche Kriegsmarine Products
Post by ModelMonkey »
Model Monkey is happy to announce new 3D-printed products for Deutsche Kriegsmarine subjects.
First product ready is a set of accurate, highly detailed, one-part, domed, 4-meter SL-8 Rangerfinders for heavy warships of the Bismarck, Scharnhorst and Hipper classes as well as the planned H-Klasse super-battleships and the aircraft carrier Graf Zeppelin.
These rangefinders were very conspicuous features and most kits' rangefinders are out of scale, lack detail and/or have seams that are difficult to smooth.
These are available now in 1/100 (set of four), 1/200 (set of two and set of four), 1/350 (set of four), 1/400 (set of four), 1/570 (set of twelve), 1/600 (set of twelve) and 1/700 (set of twelve). [edited to include 1/100, 1/200, 1/400, 1/570 and 1/600]
1/100: http://www.shapeways.com/product/G8HKNN ... d=60687248
1/200: https://www.shapeways.com/product/UK52Y ... d=60683139
1/350: http://www.shapeways.com/product/EKWL8X ... ngefinders
1/400: http://www.shapeways.com/product/XZ2T7V ... d=60678207
1/570: http://www.shapeways.com/product/ZN469N ... d=60680218
1/600: http://www.shapeways.com/product/M76T38 ... d=60678324
1/700: http://www.shapeways.com/product/DRRHJN ... d=60677980
The 4-meter SL-8 rangefinder served the 105mm anti-aircraft battery of many World War Two, heavy German Navy warships including Bismarck, Tirpitz, Scharnhorst, Gneisenau, and the heavy cruisers Prinz Eugen, Admiral Hipper and Bl�cher. These rangefinders likely would have been carried by the aircraft carrier Graf Zeppelin and super-battleships of the planned H-Klasse.
See other fine Model Monkey designs 3D-printed by Shapeways in many popular scales for your models here: http://www.shapeways.com/shops/model_monkey
Some part cleanup will be necessary. During the 3D printing process, a waxy substance is used to support certain part features. Although the parts are cleaned by Shapeways afterwards, some waxy residue may remain. It can be safely removed with water and a mild aqueous detergent like �Dawn� dishwashing detergent, baby shampoo (no conditioner) or "Simple Green" using an old, soft toothbrush, Q-tips or pipe cleaners. Customers report that "Bestine" and "Goo Gone" also work well.
During the printing process, liquid resin is cured by ultraviolet light. Microscopic bits of resin may remain uncured. Let your parts sit in direct sunlight for a few hours to fully cure the resin before painting.
Once your parts are fully cured, if desired, careful use of an inexpensive �air eraser� emitting common household baking soda can help smooth surfaces and remove any unwanted �frost�. Similar to an airbrush but much cheaper, air erasers can be found on Amazon.com. Models by Harbor Freight and Paasche are popular.
Water-based acrylic paints meant for plastics is strongly recommended. Other paints, especially enamels, may not cure on Frosted Detail 3D-printed plastics.
� Model Monkey Book and Hobby. This 3D-printed item may not be copied or recast.
Christoph Mentzel
Re: Model Monkey Deutsche Kriegsmarine Products
Post by Christoph Mentzel »
Hello Steve,
that's cool :thumbs_up_1:
very welcome and they come at the right time for me :-) ! I will start at next my Tirpitz so I can see how they fit and worked :cool_2:
Will you make some more Kriegsmarine stuff ?
directors for example ?
Best regards
Chris
biggles2
Post by biggles2 »
How about generic, or Kriegsmarine mines in 1/350. Nobody wants to make them. :wave_1:
Thanks so much, fellas!
Yes, more DKM subjects coming in a little while, including highly detailed directors.
Regarding mines, just need some good, dimensioned, 2D drawings to see if they can be printed. If they can, I'll add them to the queue.
1/400 scale SL-8 Rangefinders are ready: http://www.shapeways.com/product/XZ2T7V ... et-of-four
These should be a big help to fans of 1/400 scale Airfix, Heller and JSC (card models).
1/570 scale SL-8 Rangerfinders are now ready for Revell.
Box art: Scalemates.com.
Seeadler290
Post by Seeadler290 »
Bravo Steve! These look terrific.
Will likely pick up at least one set in both 1/350 & 400.
Eager to see what is next!
M. A. DeBacker
Wine Country architect and museum artillery repairs
Special Navy U-Boot Type XXIII 1:72
Revell DKM Bismarck 1:350
Tauro RN Fiume, Pola, Zara, Gorizia 1:400
Heller DKM Admiral Scheer 1:400
Revell DKM Schnellboot S-100 1:72
Thanks so much for your patronage!
1/200 scale SL-8 Rangefinders are now ready.
Recommended for:
Trumpeter 1/200 scale Bismarck: https://www.scalemates.com/kits/148922- ... 2-bismarck
Hatchette 1/200 scale Bismarck: https://www.scalemates.com/kits/266786- ... e-bismarck
Angraf 1/200 scale Graf Zeppelin: http://sklep.gpm.pl/en/modelcard/ships/ ... raf-1/2008
GPM 1/200 scale Bismarck: http://sklep.gpm.pl/en/modelcard/ships/ ... ser-frames
GPM 1/200 scale Tirpitz: http://sklep.gpm.pl/en/modelcard/ships/1/200/tirpitz
GPM 1/200 scale Admiral Hipper: http://sklep.gpm.pl/en/modelcard/ships/ ... ser-frames
Halinski 1/200 scale Scharnhorst: http://www.halinski.com.pl/indexgb.php?link=2
Scharnhorst class fans! An accurate and highly detailed set of 10.5-meter and 6-meter rangefinders is now available. 10.5-meter and 6-meter rangefinders served the 280mm main battery of World War Two-era German Navy battleships Scharnhorst and Gneisenau.
1/700 scale: http://www.shapeways.com/product/UBWKDC ... d=60833133
1/600 scale: http://www.shapeways.com/product/KTSDZ7 ... ngefinders
1/570 scale: http://www.shapeways.com/product/D3EXFV ... ngefinders
1/400 scale: http://www.shapeways.com/product/V8AP3A ... d=60836440
1/350 scale: http://www.shapeways.com/product/GKLRM8 ... ngefinders
Recommended for:
- Tamiya 1/700 scale Scharnhorst (# 77518)
- Tamiya 1/700 scale Gneisenau (# 77520 and 31802)
- Airfix 1/600 scale Scharnhorst (# 04206)
- Revell 1/570 scale Scharnhorst
- Revell 1/570 scale Gneisenau
- Airfix 1/400 scale Scharnhorst -or- Gneisenau
- Heller 1/400 scale Scharnhorst
- Heller 1/400 scale Gneisenau
- JSC 1/400 scale German battleship Scharnhorst, tanker �lschiff 4 (ex Adria)
- JSC 1/400 scale German battleship Gneisenau (two full models in 4 versions)
- Dragon 1/350 scale Scharnhorst 1943
- Dragon 1/350 scale Scharnhorst 1941
rmilas@illinois.edu
Post by rmilas@illinois.edu »
Hi,
The parts you make are incredible. These new parts for Sharnhorst and Gneisenau look great. Is there any chance you might consider making a new stack cap for the 1/700 Fujimi Deutschland/Lutzow? I'm referring to the taller stack cap that was used when the ship served in Norway and later. The Fujimi kit can be rather easily backdated to this period, but I've always been concerned about being able to add and accurate stack cap for this period. Thanks.
Rick
rmilas@illinois.edu wrote:Hi,
Rick
Thanks, Rick!
Regarding Deutschland/Lutzow, I have no authoritative, dimensioned 2D drawings from which to design a 3D-printed Deutschland/Lutzow stack cap. If you can provide good references I'd be happy to give it a look and see.
rmilas@illinois.edu
Thank you. I'll see what I can find.
Rick
rmilas@illinois.edu
Yes, May 10-12 42 would work for that cap.
Rick
