Cleaning resin cast parts and kit- Puzzling problem?
JimVarnellABH2USN
Post by JimVarnellABH2USN »
I am working on the Orange Hobbies 1/700 scale NEWPORT CLASS LST, I have found that the "de-mold chemical" has left a residue on the kit and my normal practice of washing with warm soapy water is not removing it. My CA glue just seemed to slide around as if it was an oily surface.
My question is what is something else I can try to remove this oily film from the kit? I don't want to use anything to harsh that will damage the kit, and my previous practice of washing resin kits with warm soapy water is just not enough for this particular kits de-mold solution.
Any advise would be helpful and thanks for any and all help with this puzzling problem.
Jim Varnell
ABH2 USN/RET.
89-00
Eastern NC Modelworks
Up coming projects:
(Table 1 underway)Feb.2017
Re: Cleaning resin cast parts and kit- Puzzling problem?
As discussed in the FAQ section: viewtopic.php?f=5&t=975#p609162
JimVarnellABH2USN
Thanks Timmy for the link, helpful.
Jim Varnell
ABH2 USN/RET.
89-00
Up coming projects:
djandj
Post by djandj »
I regularly use straight acetone and a toothbrush on the mail hull and superstructure parts for tough release agents.
