Questions about using Putty
Jon
Re: Questions about using Putty
Post by Jon »
I use automotive body putty such as Bondo.
I also use Mr Surfacer for minor filling.
Then I use nail polish remover if I can get into the area with filler to smooth once dried. Otherwise wet sandpaper.
http://www.f-16.net
http://www.c-130.net
Building:
1/48 Lancaster (HK)
1/350 Akagi
1/350 IJN Kongo
hawkeye3d
Post by hawkeye3d »
I've tried a whole bunch of stuff including spackling compound. The best, so far is Vallejo's Plastic Putty. It's water based which makes clean up very easy. It comes in a tube with an elongated nozzle which makes crack filling a breeze. Best clean up tool, my finger, or a slightly damp Q-tip, it's fast drying and sands easily.
Bob
EJFoeth
Post by EJFoeth »
As far as sanding goes: I would not use any electrical tools :smallsmile:
