Brass Mounts
sebanelli
Brass Mounts
Anyone know where in the UK I can buy finished brass hull mounts with which to display my finished models on plinths? I'm not really interested in using pieces of cut tubing or wood blocks etc. but proper museum standard/style mounts to attach to both the hull and plinth. Many thanks.
- Sten Ekedahl
Still surprises me why any of the leading suppliers of our hobby has not added this to their catalouge.
According to numerous questions on this and other forums, it seems like a constantly sought after item. Since some builders manage to find and use them, they apparantly exist. In my opinion, the retailer who finds a source for this will have very good sales.
Sten Ekedahl
Maj. (Retd) RSwAF
Maj. (Retd) RSwAF
Karsten
Les, I was going to say the same thing about the Lighting Supply.
Another thing you could do is pick up wood pieces at a craft store and giuld them in Gold/ Copper Leaf....Gold leaf can be time comsuming on larger items....I once did the exterior of a antique Claw Foot Tub but little wooden parts shold be a breese.
Karsten
Karsten
- Sten Ekedahl
I have checked all these types of stores (i. e. chains of stores) in Sweden and none of them carries these items nor have ever heard of them! And I think this is also the case in many other countries. So my earlier comment is still valid. The hobby supplier with the greatest initiative will have a big seller if they make the effort to include brass pedistals in their catalouge!les wrote:Look at an electric or hardware store for lamp finals (the things that hold a lampshade on the lamp).
Sten Ekedahl
Maj. (Retd) RSwAF
Maj. (Retd) RSwAF
- les
- Sean Hert
If you want the posts with the threaded bottom and top, try this- bottom right of the page;
http://www.lampshop.com/Merchant2/merch ... S_ADAPTERS
You are looking for LAMP SHADE RISERS not FINIALS.
http://www.shipmodels.info/mwphpBB2/viewtopic.php?t=635
Sean Hert
Sean Hert
- David Griffith
- Location: Waiting for HMS Glatton in resin. Not holding my breath!!
You could try the Model Dockyard from Truro in Cornwall.
Their website is http://www.model-dockyard.com
They are quite likely to have what you're looking for and their mail order delivery system uses the same Stargate wormhole technology as White Ensign.
David Griffith
David Griffith
"For scientific leadership, give me Scott. For swift and efficient travel give me Amundsen. But when you are in a hopeless situation, when you are seeing no way out, get down on your knees and pray for Shackleton."
sebanelli
- Sean Hert
JWPSAV
Mounting Brass
If you have a good cigar store in your town, check for brass Snuffits (used for putting out cigarettes). They are inexpensive and work great for mounting ships.
