Hi guy�s
I am planning to built kgv 1/350 scale with an anchorage diorama.
My problem is how to cover any gaps between the hull and the surface. Up to now I used to cover the gaps with cotton, but this was for ships under way. In the anchorage that I am planning this may not look so realistic.
Any tips ?
Thank you ??
Anchorage diorama
- Gabor
Re: Anchorage diorama
Hi,
I offer this product to your attention:
https://www.ebay.com/itm/AK-Interactive ... 3338562944
Use a needle or a piece of wire for distributing the gel around the hull. You can find such products at other manufacturers, e.g. Vallejo, too.
Non sibi sed patriae
Cheaper alternatives that may be easier to procure include the acrylic gel mediums used by artists, available at regular art supply stores.
- wefalck
Yes acrylic gel from artist supply houses is the way to go.
Eberhard
drasticplastic
Similar to this: https://www.amazon.ca/Liquitex-Gloss-Su ... 8682&psc=1 Also made by different brands and available in artists' supply shops. It also acts as a glue!
- wefalck
I also stipple it onto water surfaces with a bristle brush to simulate the effect of gusts.
And I mix it with ordinary crystal sugar to sculpt breaking waves. Cheap and effective.
Eberhard
tegunn
Use the acrylic medium as already suggested keeping your gap around the hull as small as possible; filling and blending in with the sea color..Mask off the model at the w.l. with blue masking tape to guard against splash..
Future Project: TBD
Future Project: TBD
- David Griffith
- Location: Waiting for HMS Glatton in resin. Not holding my breath!!
Use some rough surfaced watercolour paper glued to the base to give a bit of underlying texture. Fix the model to it. Paint the paper in your chosen colour. Then put the gel medium down and stipple or twitch it with a brush. Putting the transparent gel on top of the paint will give a sense of depth to the water surface.
"For scientific leadership, give me Scott. For swift and efficient travel give me Amundsen. But when you are in a hopeless situation, when you are seeing no way out, get down on your knees and pray for Shackleton."
