Hi,
I made my carrier hull with wood fram and covered it with balsa. I have cover all the surface with drywall putty, looks great but I would like to seal it before painting. Which kind of 'sealer' should I use, Future? Any good varnish?
Patrick
Best way to seal drywall putty
- reigels
Re: Best way to seal drywall putty
Future and varnish are probably too thin. I'd recommend spraying with Kilz spray primer which should be available in any hardware store.
Covers with a pretty heavy coat, fills sanding marks well, drys flat, fairly quickly and can be sanded smooth.
Here's a sample photo: http://www.lowes.com/lowes/lkn?action=p ... lpage=none
Hope this helps
Hope this helps
-- Scott
I can not find Kilz here in Canada, I wonder if Muttpodge could do the job?
- kevinb120
there is another product, a shelac spray primer called B-I-N by zinsser(home depot carries this brand). Pretty incredible stuff and shelac sticks to EVERYTHING, so watch your fingernails....
Local paint stores should carry one of the two brands.
of all the things I've lost, I miss my mind the most
....I think the carpet monster got that too!
