1/700 Scale PE 20mm Oerlikons with Shields
Gone Asiatic
Post by Gone Asiatic »
Does anyone have an effective technique for attaching the tiny shields to the guns? The two I attached to HMS STARLING are a little crooked; I didn`t have the patience for attaching the shields to all 36 20mm guns aboard USS ALASKA.
Crazy glue can be so unforgiving!
No Quarter Asked - None Given
Re: 1/700 Scale PE 20mm Oerlikons with Shields
Gone Asiatic wrote:Does anyone have an effective technique for attaching the tiny shields to the guns? The two I attached to HMS STARLING are a little crooked; I didn`t have the patience for attaching the shields to all 36 20mm guns aboard USS ALASKA.
Brush on a little accelerator (sp?) aka "zip kicker" onto one of the parts you are going to attach. Put a tiny drop of CA on the other part and touch them together - 90% of the time they'll hold fast with the CA touching the accelerator. Otherwise you'll be picking up sheilds all day. I used this techinque on the shields on my 1/700 USS Independence (CVL-22).
mike mccabe
Starling Models
Starling Models
Post by mike mccabe »
I use thick CA glue and thin wire and toothpicks. Use PVA glue to attach the gun to the toothpick, then dip the wire into the CA to get a very small blob of glue, dab this onto the shield and use tweezers to attach to the gun base. It will hold after a second or two.
Mike
