would this work other then evergreen sheets
guest
hello there,my local hobbyshop is useless for evergreen sheets to get,i found this product called k&s engineering plastic clear petg/polethylene terephtalate copolymer.just wanting to know if i use ca glue on the bottom to attatch to balsa wood not sealed,it should l be ike evergreen,just dont want the ga to come though damage the top which i want to paint.i got .030 thickness,so i hope this work.let me know any comments cheers
RNfanDan
I am not a chemist, but polyethylene is not a material most CA works on (hence the polyethylene nozzles on most CA tubes). However, as it is altered substantially in its molecular chains, I am uncertain if this holds true with polyethylene teraphthalate.
Werner may be a good guy to ask...
- les
- Rob
Irish Yamato
