1/350 USS Yorktown CV-10 (1945) - Trumpeter
- pbudzik
- Jose Chaica
- Model Monkey
Nick, Paul, Bob, Jose, J. Soca, gtb-red, Torben, thank you all!
Improving the Hangar Deck overhead
The real ship's Flight Deck was supported by various structural girders that were visible from below inside the Hangar Deck. The space enclosed by these girders in the midships area contained various offices, berthing and ammunition handling rooms associated with the air group. None of these details is included in the Trumpy kit. Since I opened up all of the Hangar Deck roller doors on the kit, the absence of any overhead details would be conspicuous therefore they would have to be scratch built. Here you can see some of the work to add transverse and longitudinal girders as well as the midships area containing the air group's compartments.
Forward and aft of the midships Air Group compartments, the space enclosed by girders was largely open to the hangar deck below except for the space immediately to port of the aft elevator. (I chose to build that structure on the bottom of the kit's Flight Deck parts therefore it isn't visible in the images below.)
The butt straps are cut from .010 thick Evergreen styrene strips then sanded very thin after installation.pbudzik wrote:What did you use for all the vertical pieces along the hull?
- Here, the fore transverse girders are installed. AOTS drawings indicate that the transverse girders on the real ship varied in height and were not spaced evenly. Note that four longitudinal girders between the forward elevator and midships Air Group compartments have not yet been fabricated nor installed. Some minor adjustments to the alignment of the girders will be made.
- Dave Wooley
- JIM BAUMANN
excellent methodology and really clean and crisp.
enjoyable read and presentation!
JIM B
JIM B
- Sleepwalker
- nick
- Location: Queen City of the South - Cebu City, Philippines
- Avery Boyer
Spectacular work
- Model Monkey
Dave, Jim, Bob, Sleepwalker, Nick and Avery, thanks so much!
Improving the structures above the Fantail
There were various structures containing aircraft engine shops, berthing, oxygen and CO2 transfer shops, etc., at the stern below the flight deck and above the fantail on the real ships. Replacing the kit's heavy framing with the lighter latticework of reinforcing ribs seen in photos helps improve the kit parts' appearance.
- The heavy framing has been trimmed away and 69 rib parts have been added to the structure. The ribs are composed of Evergreen 0.010" x 0.020" strips. Note that consistent with the photo of Hornet, the framing on the port side (left side of photo) is intentionally installed slightly lower than framing on the rest of the structure.
- CV-12 Hornet's stern structures over the fantail looked like this. The structures are typical for the class but Tracy White reports that Hornet's stern flight deck overhang CATWALKS seen in the photo are NOT typical for USS Yorktown or USS Essex. If you are building either of those ships be sure to check your references before installing PE catwalks.
- johndon
Re: Detailing USS Yorktown CV-10 in 1/350 scale
Great work Steve, I'm keeping a close eye on this one.
John
John
- gtb -red
Man Steve, I look back at your progress just outstanding man.
- Model Monkey
Bob, John, gtb-red, thank you so much!
Installing new aft flight deck structural columns
The flight deck above the fantail is supported by two very large structural columns. The kit's parts (B3 and B4) detailing appears heavy. I decided to replace the kit parts with scratch-built columns with lighter detail to match photos of these columns of the real ship. The scratch-built starboard column is composed of 18 parts. The port column extends upward onto the aft face of kit part C19 and is composed of 22 parts.
Click on thumbnails to see larger image
- Here the scratch-built columns have been installed. Note that the reinforcing
fillets (the triangular webs) are not uniform in that the upper and lower fillets
are fixed perpendicular to the column centerline. The middle fillets are fixed
parallel to the deck. The fillets have an opening in them as well. The edge of
kit part C13 is capped with a styrene strip replicating the real platform's edge
reinforcement (noticeable in photos of the real ship).
Damn Steve...that's really fine work.
