1891.. not 1941 !! ==> HMS Hood 1/700 pre-Dreadnought
JIM BAUMANN
Re: 1891.. not 1941 !! ==> HMS Hood 1/700 pre-Dreadnough
Post by JIM BAUMANN »
@ Pascalemod
Whilst I taper my own masts.... :cool_2: :big_grin: :thumbs_up_1:
doing ( double ended !) yard arms --repeatable in size and shape- and accurately .... has eluded me !
Master Barrels produce 2 sets in 1/700 and 2 sets in 1/350
( for my Hood model I used the smaller of the large ones (!) from the 1/350 set )
I bought a large amount of yard arms at the Telford show one year
You can buy them from Starling Models ( at about the same price as I paid (!) :cool_2:
https://starling-models.co.uk/en/1350-b ... -no-1.html
meanwhile
review here of 1/700
http://www.modelwarships.com/reviews/mi ... eview.html
HTH
JIM B :thumbs_up_1:
pascalemod
Post by pascalemod »
JIM BAUMANN wrote:@ Pascalemod
meanwhile
HTH
JIM B :thumbs_up_1:
Top stuff! Wish Id have found them before my Mikasa, otherwise wouldnt have had to cover mine in "canvas"! Thanks!
JIM BAUMANN
some news at last on this project!
gentlemen...I made an error in an earlier update when I said the Burt book contained shipbuilders original drawings of this HMS Hood
the ( new edition) of the Burt book indeed does have good drawings --and some excellent resolution double-page photos
.....but the most excellent admiralty drawings referred to ( which answer sooo many mysteries!) of many RN pre-dreadnoughts
are to be found in this newly published very worthy volume by Norman Friedman
--an excellent ( must -have!) buy for any pre-dreadnought RN fan!
in the meantime
the location of the turrets access steps can be gleaned from some of these ( excerpts of ) drawings at very usable res too!
I made and installed the 2 x large boat booms--which overlap off-set midships on the cradles fwd / aft of the funnels
I spent some time trying to replicate the goose-neck end of these spars-- making the plates of thin paper attached with thinned varnish and backfilled with a drop of CA
I also made and installed the 3" Q/F gun carriage tracks of wire for the fwd and aft fighting tops
-- sprung around the mast at the wire circle split and sealed in place with matt varnish and a drop of CA
The aforementioned Q/F tracks need some carriages...
I made these by bending some boat cradles from my brass stash ( spare Henri iV Combrig PE )
they are very small-(!!! :smallsmile: ) - but add a bit of interest to otherwise dull insides of fighting tops
installing the Q/F guns was challenging, insofar as getting them over the rails... and under the deck ....
without damage to gun or rail... ( !!! ):Mad_5: :Mad_6: :mad_2: :censored_2:
more soon- :wave_1:
marijn van gils
Post by marijn van gils »
She's looking really good Jim! :thumbs_up_1: :thumbs_up_1: :thumbs_up_1:
Those ladders to the turrets look quite weird but wonderful. :smallsmile:
That's not much room for installing those guns indeed! What glue did you use?
Thanks for the steady stream of helpful tips,
Marijn
JIM BAUMANN
Modelling against the clock now ....-- Telford is looming .... !! :Mad_6:
@ Marjinn....
As you know the contact area of many of these tiny guns and other small items etc is very small--
and CA superglue in that type of application , can often be decidedly.... UN-super... not having much " grab "
My favourite concoction for this is to use either:
Thinned white glue, excellent grab --but an unsubtle media ( that dries very quickly ( sometimes too quickly ..)
and this gives insufficient wiggle time
or in this instance where there are no "hanging " loadings I use Humbrol Matt cote varnish ( in the glass jar ) that has had the lid left off for months...
This gives a goooey sticky paste ( can be re-thinned) that has huge instant grab--but can be wiggled.
i will dry out and go hard in about 1 hour or so
on both of the above I then afterwards apply a droplet of the very runny Pacer ZAP pink CA glue on the end of a cat whisker or wire
This droplet spreads wraps around in a thin film and penetrates any small fissures giving a bit of strength to the assmbly
meanwhile....
I added the navigation lights , small strip of paper with a 90 degree bend and with a piece of brass rod for the lantern
and made all the QF guns-of which there were 17 ( !! )
and being dissatisfied with the first set of guns....
I removed and
I remade all the guns that I had previously fitted ... ( !! )
The shoulder pad / aiming ladder crutch on the left side of the gun
( this can also be central and of various shaes and configurations..)
( which on the real thing in 1/1 scale looks a bit like this...
in 1/350 I managed this
in 1/700 I had to simplify-as I could barely see it and certainly could not manipulate it accurately
( WEM handrail cut as per image )
Rather harder were the Nordenfelt 1" machine guns
the real thing came in various sizes with barrel fitments ranging from 4 to 10 barrels.
They could fire 600 rpm (!) and were supplied with ammunition from the vertical hopper toward the mid rear
Fortunately the four guns on Hood had shields in the photos I had -phew!
-allowing me to simplify and not construct all the really hard bits !!!
I selected a piece of elderly PE( :L'arsenal PE ?)
that usefully had what I needed-- etched corrugations top and bottom
These would make the barrels....
the PE shields ( Unknown source ) would hide the rest :smallsmile: :cool_2:
Installed they sort of look passably like the real thing in the photos
The work with small guns continued into the three fighting tops,
adding the gaff spars , upper mast rigging spreader supports , davits etc
a lot of time expended on small details, but I hope the collective impression of the ship will reward the effort and time.
The entire ship--being Mediterranean based ship had full sun-awning stanchions set up all round.
The upper fwd and aft bridges also had awing stanchions--but so as to afford a bit of shade overlap the tops of these had an offset
I made these of thin brass strips cut from 1/350 railing PE longitudinals-
-a ready and repeatable source of raw material to work with :thumbs_up_1:
More soon!!
JIm Baumann :wave_1:
Timhan
Post by Timhan »
Jim, wonderful work of art as usual. I have a question - what colour paint did you use for the
funnels and masts?. Was it your own mix or an available colour?. I only ask as i am looking for
something similar for another project i am planning.
Tim.
marijn van gils
Most excellent and educational!!! (as always... :) ) :thumbs_up_1: :thumbs_up_1: :thumbs_up_1:
Many thanks for the thickened varnish trick. That's a very good idea indeed!
Marijn
Rob
Post by Rob »
terrific work mate
zs180
Post by zs180 »
This is coming along wonderfully!
Hope to see it in flesh at Telford!!
JIM BAUMANN
Apologies for indifferent quailty photos in todays update...
my usual " bench " point and shoot had flat batteries so I reverted to another old point and shoot camera
-- which is alas noticeably of a previous generation !
( for finished model shots I use canon Eos 600 D SLR on tripod etc )
but I find the canon too un-handy at the bench when photographing in progress , otherwise I plod on and complete things and fail to explain.
JIM BAUMANN
Onwards....
after fitting ( surprisingly arduously) the deck edge railing of very thin (over-etched :thumbs_up_1: ==> makes thiner still )
WEM ultra fine PE and gently depressing some- but not all - of the wire spans to give a gentle droop( as per original photos)
I turned my attention to the awning supporting poles
Hood being Mediterranean based was fitted with a vast amount of sun-awning supporting stanchions, dece eged as well a down the centre-line
these were made from 1/350 P E handrail longitudinals -
that way consistency in size of the material is guaranteed
cutting them from the handrail means that visual measurement is easy when judging cutting between the stanchions to give consistency
Each deck-edge stanchion--whilst mounted in cantilever mountings outboard of the rail -
-nevertheless had a tall supporting strut inboard also!
the same also on the aft deck
Ships boats that were suspended outboard on davits often( but not always) had a " griping" (sp /) spar to which the boat was strapped
against canvas/ rope covered pads
arrowed below
These spars had" stand-offs" in a vertical " V " so that boat would be suspended below the end of the davit concentrically
Making these to scale in 1/700 and not clunky and overscale whilst retaining structural strength was potentially tricky (!!)
so I err... simplified.
Uisng 1/350 hand-railing of appropriate width for correct distance davit spacing I cut some spars integral with stand-offs
Once painted by brush they took on a more circular shape, canvas pads were added with blobs of white paint
( note that in hood these spars varied from natural timber to painted white from year to year !!
The real ship had the boast suspened by ots block and tackles
I took the short cut of gluing the boat to the spar and will be adding the block and tackles afterwards
The full complements of boats is now in place
a few more bits to add and then flatcoat, rig ,(!!) make sea and voila!
My new ship project is looming already-- so Hoods completion will be welcomed!! :heh: :thumbs_up_1:
more shortly ! :wave_1: :wave_1:
JIM BAUMANN
another small step..
The flat coating-using my trusted Windsor and Newton Galeria varnish
( airbrushed thinned 50/50 with distilled water )
was completely successful ( phew! )
a small detail had been bothering me.... that of the large name letters aft...
when my alps printer was still alive I would have simply made a gold decal, alas my current printers are simply are not good enough
in any case these letters stood a bit proud of the ship.
Handpainting the name ( for me alas ) was out of the question
So I found a 1990's PE set from WEM in my old PE boxes -- in BRASS :cool_2:
The description of the fret ( and / or parts thereon) in those days was etched out-- not relief etch engraved.
alas the lettering:
wHite ensign m0 Dels 1/700 Hms D 0d0
meant I was till missing an O tediously the 0 from the 700 was a noticeably difference font...
I searched all my old PE stash but did not have a second old fret
from an old IJN cruiser GMM set of similar vintage.... in stainless steel there were also more etched thru bits of lettering;
These were slightly smaller still and easier to cut being attached only one side-( so I thought )-but the springy stainless steel
made it hard work , and many letters pinged thru the air--despite being cut inside a plastic bag !!! eh..?!
and H's on that fret were precious ( plenty of O's and even a few smattering D's !!)
once these were cut and retrieved successfully...
I had to paint them
I used Tamiya gold and contrived to stand the painted letters on end with the paintbrush so aid drying and removal from post -it-note
They were attached onto clear varnish ( on the end of a moistened cocktail stick) and then washed gently with thin black to dull down a bit
end result is alas a wee bit over scale...( !!) but the look is -I think satisfactory
and better than not at all
===> onwards !!!
-3 weeks to go till Telford...
no pressure!! :big_grin: :Mad_6:
JB
I love how you tackled the name on the stern - inventive! Looks great, too!
JIM BAUMANN
still intensely modelling to get her completed.... in time for Telford
( now exactly 14 days to go...)
where I to be retired it would be easy... :thumbs_up_1:
-alas running my own business it does rather put a aqueeze on spare time --when I am not just simply tooo tired !!
but I have managed 18 hours or so of hold-your-breath-rigging so far.... :cool_2:
the first thing that I did was to install the painting 'chains'
( these would be substituted for hemp ropes when funnel painting/ cleaning--but thin chains were roved through the pulleys when not is use as the hemp ripe would rot with potentially disastrous consequences!
The lower shrouds on the real ship were quite monstrously thick cables-- the upper shrouds only slightly thinner !!!
I have rarely made such thick stretched sprue to rig with!
( My method is SbS here )
viewtopic.php?f=4&t=37536
The aft boat boom( derrick?) was slightly thicker in diameter than the fwd one
( I guess so as to be able to be lifting heavy steam pinnaces)
As such the the aft boat boom also had additional purchases on its pulley blocks !
These large pulley blocks --for consistency--were made of 1/700 aircraft wheels with the undercarriage struts snipped down so as to be usable as the chain attachments.
The funnels stays were quite nerve-wracking-- as the attachment on the funnel is minimal-
-and the 'landing' on the deck is " blind"
The overall effect was quite pleasing
The awning rigging interwoven by the shrouds was a test of patience
with the foot ropes--made of sprue ( muuuch thinner than PE ) was also testing...(! :Mad_5: :Mad_6: :censored_2: :mad_2:
fortunately there were only 2 yards that carried them
The signal halyards ( incomplete in the photo ) were made all as 'twin' lines
At the rate I am going I guess another 10-15 hours of rigging...
More soon
Jim Baumann
1:6000
Post by 1:6000 »
This is mad and completely wonderful!
pascalemod
I really wish one day you'll do a dry dock diorama of one of these early Victorian battleships!!! This thing has such tiny free board I wanna see the lot that is hidden beneath the waves!
JIM BAUMANN
@: Pascalmodel
drtdock eh...?
have a look here-- not mine-- but Italian e-chum built it!
meanwhile....
We are getting there....
The rig is now completed...--phew!
intense and careful study of the photos available eventually revealed where the bracing lines for the yards went
aft- it was -sailing ship style to the gaff-- was a ' discovery !
The Ensign was made by crumpling an old DunAgain Decal, and then washing in white and painting in crease shadows
fwd ...-- the yard braces went to the upper fighting top.
All the sun awning rigging was done around the perimeter as well on the bridges and fwd and aft supports
The ships boats slung outboard had canvas straps-- these were made of ' flat'-stretched sprue in brown plastic
The advantage is that one can -by softening the stretched sprue with liquid cement--
get the sprue " canvas " straps to follow the ' kinks and angles of the boats
to give them a taut look-
(alas -often these straps on models look too loose / and sagging ==> - and therefore not fulfilling their function. )
the remainder of the rigging was merely slow and tedious- !
The firs coast of wet-on-wet sea paint have gone on
more coats and layer today hopefully
:wave_1: :wave_1: JB
wefalck
Post by wefalck »
One thing that has puzzled me for a long time, Jim, is the stacks of PE frets you must have. How the heck do you find anything in them - and why does one have these stacks of them, they are not cheap ... ?
The one, who struggles just with a few internal struts in a funnel at 1:160 scale only ... :scratch:
Eberhard
Image Image Image Image
marijn van gils
Fantastic work Jim! She looks beautiful! :thumbs_up_1: :thumbs_up_1: :thumbs_up_1: :thumbs_up_1: :thumbs_up_1:
And I guess she will be ready comfortably in time before Telford.
I wish I could come over to see here there in the flesh... :(
Will the Bretagne still be your next project?
Marijn
JIM BAUMANN
@ wefalck
hahah! its a relic of my somewhat less discriminate buying pattern over the last 25 years... :cool_2: :cool_2:
and whilst modern PE frets for large 1/350 projects ARE expensive per se
my stock--albeit considerable ( !) was monetarily much less than nowadays
and in any case-pro-rata --- brass is much cheaper than beer or petrol !
...==> that is how I sell it to myself!
Much of the OLD( 1990's :big_grin: ) PE is unusable for ' modern' / ' fine' modelling
BUT can supply the raw material for a number different aspects of re purposing
( awning stanchions from handrail, aircraft wheels for pulleys-- even the lettering .
Much old girder work PE can be reused
etc etc
@ Marjin...
YES !
cheers
JB
Return to “Completed Models”
